[DFW] What have you done to your G Today?
Old Nov 17, 2010 | 03:35 PM
  #1996
LordFappington's Avatar
then Id have to cut a big *** hole lol.
Old Nov 17, 2010 | 03:48 PM
  #1997
r1forever80's Avatar
Nope, make 2 cuts and make a cowl hood.
Old Nov 17, 2010 | 07:42 PM
  #1998
Hi Jack,
We had not engineered or made any VK56DE to 6-speed bell housing adapters yet. We are currently working on an adapter plate for adapting the VH41DE engine to the 6-speed and after we complete that version then we will work on the VK56DE version. So right now, nothing to adapt the VK56DE yet.
We had for a local off road buggy that used a VK56DE engine, made an adapter for the front timing cover to allow an early Q45 CAS unit to fit and an early Q45 engine harness was used along with the matching ECU. We reprogrammed this ECU to run this VK56DE engine. The engine runs a set of our JWT C8 cams and valve springs and the customer had adapted on some "Extrudabody" throttle bodies and made a common intake plenum with a Ford Lightning MAF sensor on the inlet pipe. This made 400 wheel HP and here is a link to a dyno of this VK56DE buggy:
http://www.youtube.com/watch?v=md-hzgUrX-s
You can check with www.mckinneymotorsports.com about the possibility of making engine mounts and a transmission crossmember and maybe doing the engine harness wiring work too.
Contacting Mckinney Motorsports now.
Old Nov 17, 2010 | 07:47 PM
  #1999
JBF's Avatar
JBF
you could probably get in contact with the guys at Drift Emporium in Georgia. They have 2 G35s with boosted VK56s. I'm pretty sure they're running the factory 6mt...
Old Nov 17, 2010 | 07:48 PM
  #2000
Thanks, I'll look into it.
Old Nov 17, 2010 | 07:56 PM
  #2001
hound's Avatar
yeah...
Old Nov 17, 2010 | 08:08 PM
  #2002
hound's Avatar
Old Nov 17, 2010 | 08:16 PM
  #2003
hound's Avatar
Old Nov 17, 2010 | 08:30 PM
  #2004
acidjake75's Avatar
sux that Noahs car got stolen...
Old Nov 17, 2010 | 08:50 PM
  #2005
VicariousVision's Avatar
I crapped my pants when he turned his engine on....wow. Just wow.
Old Nov 17, 2010 | 09:01 PM
  #2006
Everything is in work ( Flywheel, trans adapter, mounts radiator ect. Hope to complete first car in after Christmas or January. Please check back after Christmas… Mack McKinney
So, hmmmm
Old Nov 18, 2010 | 06:48 AM
  #2007
TrixR4kidz's Avatar
Rob, my friend Brandon and I, installed my ART pipes and TDX V2. Man, that thing was a B**** to put on. Sounds absolutely redic!
Old Nov 18, 2010 | 01:32 PM
  #2008
So this VK swap keeps looking a little discouraging each time I try to get answers lol...
Hi Jack,
The years of Q45s that we upgrade the ECUs are 1990-95. The 94-95 are a newer version ECU than the 90-93 so those would be better.
You will have some work to get the engine in. I have now idea as to whether or not the existing engine crossmember would be in the correct space and allow the engine to fit. Definitely will need customer engine mounting brackets and mounts, transmission crossmember, custom driveshaft, a custom transmission adapter plate (we might have in the future as I mentioned), custom flywheel, proper clutch, throw out bearing/slave cylinder system, etc.
I'll just have to wait till someone has a turnkey solution that I could try to do myself.
Old Nov 18, 2010 | 01:33 PM
  #2009
Yes we will be using the Titan computer and harness, both will be modified to work without the BCM and other body computers….Mack
So I guess as far as ecu goes I could use either one... but it doesnt make sense to me, if everyone is reprogramming them, couldnt they just reprogram the g35 ecu to do the same?
Old Nov 18, 2010 | 01:53 PM
  #2010
sexyrob's Avatar
have you talked to uprev? I think I read somewhere you could plug a VK harness into our ECU and have uprev flash it with a VK rom.
on another note I think it is discouraging to know that you'll be adding 200 lbs to the front end and probably ruining your handling characteristics. someone mentioned with the LS swap its only 100 lbs more and you can sit the engine further back. plus mods for LS are so much cheaper.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
