[DFW] What have you done to your G Today?
Old Mar 7, 2011 | 04:29 PM
  #4591
g35man04's Avatar
CLUB MODERATOR
Originally Posted by PhGit
Sweet! I'm already done then. Thanks for the explanation! I've already bought new belts and just need to put them on one of these days soon. I''ve never changed belts before but it sounds easy enough going at it from the bottom.
loosen up both idler pulleys first...I beleive 14mm bolt on the front of the pulley. Then from the bottom side after removing the under tray there will be a tensioner pulley on left side and one on right. should be 12mm bolt...crank that to your left to loosen it and pull off the belts. swap belts...then go ahead and crank it back up to where its semi-tight...tighten down the front idler pulley 14mm bolts then back underneath to put tension back onto the belts.
Old Mar 7, 2011 | 04:37 PM
  #4592
BeerViper's Avatar
Installed new Kinetix front camber a-arms and raised suspension up a little so it's more for go than for show.
My suspension was bottoming out at the autocross not doing me any good so I decided it was time to go less low! Now I know that 1/2" shock adjustment does not equate to 1/2" raise or lower overall ... this should be fun to get all 4 corners at the same height!
Old Mar 7, 2011 | 04:55 PM
  #4593
BlueBOB's Avatar
Sounds like some corner balancing and stiffer suspension are in your future
Old Mar 7, 2011 | 06:36 PM
  #4594
almost3flips's Avatar
Yeah one thing I noticed was the better handling with going lower. I want sway bars now
Old Mar 7, 2011 | 06:43 PM
  #4595
Princedrama's Avatar
i need a rear strut bar!!! LOL kinda want to get all the braces since i got the strut bar installed!
Old Mar 7, 2011 | 06:45 PM
  #4596
ezpotato's Avatar
handling > speed
but a good combination of both is amazing.
theres no feeling like a stiff suspension that confidently gets you around corners others wither away from!
Old Mar 7, 2011 | 06:46 PM
  #4597
ezpotato's Avatar
prince, you better start tracking your car or something. otherwise, spend your $ on cosmetics instead of getting all the sways!
Old Mar 7, 2011 | 06:58 PM
  #4598
honestly i don't know what i want to do at this point!! i kinda want to stance my car and lower it will stretch tires and all but i drive to aggressive to go stretch lol. i just want it to look nice and drive nicer! i can care less about going to the track
Old Mar 7, 2011 | 07:23 PM
  #4599
GryDe06's Avatar
let the rain wash it! ha
Old Mar 7, 2011 | 07:35 PM
  #4600
twalls's Avatar
CLUB MODERATOR
We still need to get together Chris.. When are you available? Engine bay looks good man.. Are you gonna throw the strut back on? Looks nicer w/out it.
Old Mar 7, 2011 | 07:39 PM
  #4601
g35man04's Avatar
CLUB MODERATOR
yeah strut bar is already back on..been for alittle while now.
Old Mar 7, 2011 | 11:18 PM
  #4602
sexyrob's Avatar
worked on clearcorners, fingertips are sore and I've only finished one so far.
holes drilled and center molded
bondo
primed
painted
LED fit
all wired up
running lights
another angle
turn signal
Old Mar 7, 2011 | 11:31 PM
  #4603
twalls's Avatar
CLUB MODERATOR
I like how it's painted your car's color, but the lights are still white, so it's still legal.. Man you're a beast w/ ingenuity.. Good work as usual man..
Old Mar 7, 2011 | 11:33 PM
  #4604
Rob now do mines in black!! Lol
Old Mar 7, 2011 | 11:34 PM
  #4605
DrewLe's Avatar
Those lights look Awesome!! So the clear corners are going back in for normal daily driving? lol
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
