[DFW] What have you done to your G Today?
Yea i'm almost positive my knock sensor is fine..i'm still gonna replace it. Has to be the harness, if i remember the code correctly its a low circuit so the wiring is damaged somewhere. I just have to figure out the right wire to buy. I'm wondering if this kit from z1 includes the whole new harness
http://www.z1motorsports.com/350_g35...oducts_id=3189
Forgot about that fact.... that's probably where the problem is
I kept thinking about this part of your statement and I'm curious.
you've been in the engine bay too much...
yeah I have a full wiring set for those.
yes the alarm system he had did have a kill on it....not sure but he did have wires running into the injectors as well.....may need to look at them...
James ooks like I need to pull off the plenums and check the wiring all around there.
ok you will be wishing you had that knock sensor when your engine blows. knock sensor keeps the engine from going to crazy when its advancing timing. soo uh.. have fun with that.
this might explain a few things chris.
He is planning on drilling into the side of the block and install a secondary intake direct to the exhaust valves
...HR style but better
