[DFW] What have you done to your G Today?
Old Apr 25, 2012 | 10:13 PM
  #12016
r1forever80's Avatar
^ha
Paid for my fuel return today. Can't wait to see what kind of #s my collection of parts put down
Old Apr 25, 2012 | 10:16 PM
  #12017
TheJanitor6203's Avatar
^ me too
Old Apr 25, 2012 | 10:26 PM
  #12018
Deemo's Avatar
^^Me 3
Old Apr 26, 2012 | 09:02 AM
  #12019
R6n350GT's Avatar
Well if you want to buy the poly gialla grill be prepared to do ALOT of work to get it to fit well..
After 2 days of grill and K2 Poly Front modifications its almost perfect..
The K2 poly front also needs some work, alot of trimming required to make the underbody fit, getting the screw clips to fit were a pain in the ***... had to shave the plastic at each hole as the clip wouldnt fit the thickness of the poly..
The passengers headlight has a small gap, the drivers fender corner has a small gap... poor fitment is the headlight area to be honest.. rest is pretty spot on. Most of the time was getting grill to fit and my JDM fog lights had to be moved as the were right behind the pillar .. man it was worth it though!
Old Apr 26, 2012 | 12:17 PM
  #12020
JaE35's Avatar
Moderator
G35 Sedan
^Are you in DFW? Haven't seen your G around
Old Apr 26, 2012 | 05:35 PM
  #12021
R6n350GT's Avatar
ohh woops, i now see this thread is a club, no im a little bit further away.... in the Goldcoast
And its a V35 not G35
Old Apr 27, 2012 | 04:21 PM
  #12023
U should have 8 valves. 2
Per corner. Each valve will have a black box on it and a black connector harness will go on that. U will hAve to configure the valves and wire up the valves to ur controller.
Old Apr 27, 2012 | 05:54 PM
  #12025
dae's Avatar
dae
I curbed my damn passenger side wheel today... anyone have any good contacts on getting some rash from a wheel buffed out?
Thanks for any help
Old Apr 27, 2012 | 06:32 PM
  #12026
gmotion04's Avatar
wheels america ?
Old Apr 27, 2012 | 07:56 PM
  #12027
Hey Stephen, why have you had so many under shrouds? What didn't you like about the first two?
Old Apr 27, 2012 | 11:25 PM
  #12028
^I just like changing things up.
Amatur that box is the connector harness for the valve. You will need to run the power and negative wire to the harness that plugs on the valve
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
