[DFW] What have you done to your G Today?
Old Sep 18, 2012 | 12:01 PM
  #12466
TheJanitor6203's Avatar
Can y'all help me out by going to this link http://www.nwmotiv.com/inmotion-voting/ and voting for my car? There is going to be a big show up here and the top 5 get a "premier" spot and some free stuff. Look for this pic.. you have to hit "like" to vote and you can only vote once. Share tos with your friends please!
Old Sep 18, 2012 | 12:16 PM
  #12467
BlueBOB's Avatar
Not sure if it's the link or what, but I don't see your ride on that site anywhere.
Old Sep 18, 2012 | 12:35 PM
  #12468
The site is kind of shitty. Were you able to get to the page that actually shows the cars to vote for? I should be the first page, 3rd row down, 2nd from the left.. Either way, thanks for trying!
Old Sep 18, 2012 | 02:59 PM
  #12469
BlueBOB's Avatar
Finally got it
Old Sep 18, 2012 | 03:02 PM
  #12470
Cool beans. Thanks for your help. Do you remember how many votes I had at the time? The website isn't working on my work computer...
Old Sep 18, 2012 | 03:03 PM
  #12471
BlueBOB's Avatar
I was vote #8... I think you're right at 5th place from a quick glance. A Z is in the lead with 20 votes and an STI with 17 or 18.
Old Sep 18, 2012 | 03:09 PM
  #12472
Yeah, the Z is a guy from group up here. But I'm new to the group so he gets all their votes lol. His Z is a freaking beast though! It's a TT setup pushing 750 hp! And the dude has a LS1 in a 240SX.. or one of those older Nissans. Last I counted, I had 7 votes which put me in 6th. The voting lasts until the 26th though so there's still a lot of time. Hopefully all my FB friends can come together to help me get in the top 5!
Old Sep 19, 2012 | 05:21 PM
  #12473
I still need all the votes I can get. I'm tied for 4th right now! It only takes 2 minutes!
Old Sep 20, 2012 | 05:04 PM
  #12474
Anybody else want to vote for me? I could use it.
Old Sep 20, 2012 | 05:28 PM
  #12475
sexyrob's Avatar
I did it
Old Sep 20, 2012 | 05:33 PM
  #12476
Thanks Rob!
Old Sep 21, 2012 | 11:31 AM
  #12477
Today I'm going to be installing my MREV2, repolished upper plenum and new spark plugs in prep for my dyno tune tomorrow. And I just happened to find a DIY for painting the valve covers today so I figure I'm going to have it stripped all the way down to valve cover anyways, might as well. Just thought I'd ask if anyone has any tips/tricks/advice for removing the valve cover. Looks pretty straight forward but I just wanted to check.
Old Sep 21, 2012 | 11:45 AM
  #12478
sexyrob's Avatar
a few things for you.. if you do end up pulling them make sure you clean off all the oil really well before doing anything. I suggest using simple green followed up by some soapy water. After everything is all dry, tape up the bottom and the insides where the sparkplug tubes go, you really don't want any paint on the inside. You should use a plastic adhesive promoter before painting, just spray it on like its spray paint. Let everything dry for a day at least a day before messing with it.
Old Sep 21, 2012 | 12:00 PM
  #12479
The diy by tollbothwilly just had like 10 minutes between coats and said to apply paint within 10 minutes then to let dry for atleast 3 hours.. if it needs to sit for a day I don't have time for it today.
  #12480
g35man04's Avatar
CLUB MODERATOR
1 thing to add is whenever replacing the valve covers back on be sure to not pinch the new gaskets when installing back into place...once pinched they are no good anymore. you will have to use alittle muscle or un-bolt most of the wiring harness around the engine to make it where its lose enough to pull off the valve covers. The back passenger corner bolts are pretty tough to get to and the OEM Wiring harness has a bracket on the backside of the engine that holes the harness in place along with a big black plastic cover that protects that area. Personally I have always just broken that black plastic cover off because it gets in the way. the valve covers have to be wiggled out unless the wiring harness and fuel line stuff is moved out of the way.
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
