DFW Lounge (NSFW)
Old May 13, 2011 | 03:24 PM
  #1546
twalls's Avatar
CLUB MODERATOR
so in essence, they just completely JACKED UP that perfectly fine 2000 vette.. <shaking head>
Different ain't always good..
Old May 13, 2011 | 03:46 PM
  #1547
fobizzle's Avatar
Quick question guys, looking at purchasing 350z suspension to lower my sedan. Does anyone know if the Nismo V3 suspension set up will work?
Old May 13, 2011 | 03:57 PM
  #1548
acidjake75's Avatar
Yep - and I was wrong about the spring rates..these bad boys are NOICE..
NISMOs have progressive rate springs 448/504 (F+43% R+48% compared to 2003 suspension) vs. 314/427 for the revised suspension.
Old May 13, 2011 | 04:02 PM
  #1549
Gitsum's Avatar
Probably a kit car....*shakes head*
Old May 13, 2011 | 04:22 PM
  #1550
jran76's Avatar
I ran the Nismo 350Z suspension on my 04 sedan, and it was great. The only thing I would say is the rear was about a 1/4-1/2" lower than the front. I added a polyurethane spacer on the rear to even it out.
I used a spacer like the one below from Energy suspension (It has to be trimmed a little, but it worked), and mounted it on the rear upper spring (rubber) mount. If you can find someone that has trimmed the rear spring mount, you could also use their leftover piece.
Energy Suspension 3/8 Spacers for the rear (part number 9.6101)...
Link: http://www.suspension.com/COILS_SPRING_ISOLATORS.html
Old May 13, 2011 | 04:33 PM
  #1551
DrewLe's Avatar
Yeah it is slightly lower in the rear. My ride height is 27" in the front and 26.75" in the rear. The just with the revised suspension though.
You find a 6MT Bibb?
Old May 13, 2011 | 04:39 PM
  #1552
jran76's Avatar
Doh.... Just noticed he is probably talking about the suspension of a Nismo Z. I had the Nismo S-tune suspension (it did not have progressive springs), so I can't comment on the ride. The same will probably hold true on the ride height though....
Old May 14, 2011 | 01:10 AM
  #1553
almost3flips's Avatar
Rob - When is this Kan guy opening his shop? I feel like I need a tune before I WOT again.
Thinking about just making a trip to Austin. Any of you guys have any experience with any other shops around here that tune?
Old May 14, 2011 | 07:37 AM
  #1554
sexyrob's Avatar
I'm trying to put the event together, I'll make a thread soon.
if you are just NA there is no reason to not go WOT, unless you are Heavily modded NA.
I've never heard of bolt-ons causing an engine to run THAT lean.
I think the group tune day will be in about 3-4 weeks.
Old May 14, 2011 | 11:02 AM
  #1555
JaE35's Avatar
Moderator
G35 Sedan
Where you at chris?
Old May 14, 2011 | 12:47 PM
  #1556
g35man04's Avatar
CLUB MODERATOR
have you heard ARC Exhaust.....the only benefit is that its light..extremely Light.....other than that the sound to me is not good...very raspy because of the material used to build the exhaust.
Old May 14, 2011 | 08:05 PM
  #1557
syshs's Avatar
Originally Posted by jran76
Old May 14, 2011 | 08:11 PM
  #1558
JBF's Avatar
JBF
Old May 14, 2011 | 08:12 PM
  #1559
Princedrama's Avatar
lol
Old May 15, 2011 | 12:15 AM
  #1560
Okay....ART pipes make my car drone SO MUCH LOUDER on the freeway. If I back up the gas fumes are crazy.
So what prices are we looking at rob? 500-600?
