Z1 VQ35 basic engine rebuild kit....
Old Feb 8, 2011 | 11:14 AM
ezpotato's Avatar
Guys, I am debating on pulling the trigger on this kit...
http://www.z1motorsports.com/350_g35...oducts_id=3546
I am aiming for about 400-420rwhp, and wanna do it safely... in the next few months, I will be getting 600cc injectors, and clutch/FW combo. APR studs as well.
I wanted to see if that looks like a good deal on a combo of wiseco pistons and eagle rods for 989$
I found this as well,
http://www.conceptzperformance.com/C...2524.155.79.71
Just a few bucks more. and no, i dont need higher end things, these will suffice for what i want.
Thoughts? I will also be posting this in the FI section, but just wanted to get local opinions if anyone has any good input..
Old Feb 8, 2011 | 11:35 AM
sexyrob's Avatar
eagle rods will hold you to about 450 hp. I actually have some going in my NA build.
Id suggest some ARP L19 Headstuds to go along with the rods and pistons to prevent head lift when you boost more.
the other thing you should look at is new crank/rod bearings when you are in there. the ones you have now are worn in for your current setup.
something else, usually at a minimum you will need to hone your block when using new pistons so the rings seat well. if they don't seat well you will have oil consumption issues and probably make lower power than you could.
Old Feb 8, 2011 | 12:19 PM
ezpotato's Avatar
define HONE your block.
Old Feb 8, 2011 | 12:21 PM
sexyrob's Avatar
http://www.ehow.com/how_4827132_hone-cylinder-wall.html
Old Feb 8, 2011 | 12:36 PM
g35man04's Avatar
CLUB MODERATOR
not a bad price for that..wish I would of done that when I was FI..would probably still be FI if that was the case...
Old Feb 8, 2011 | 01:44 PM
LordFappington's Avatar
do the ipp one i showed you emad... they are in texas.
Old Feb 8, 2011 | 01:49 PM
g35man04's Avatar
CLUB MODERATOR
which one is that Jack???
Old Feb 8, 2011 | 01:50 PM
their stage 1 short block
Old Feb 8, 2011 | 01:51 PM
g35man04's Avatar
CLUB MODERATOR
the one for 2600??
Old Feb 8, 2011 | 01:56 PM
yeah
Old Feb 8, 2011 | 01:57 PM
also the warehouse its completed in is in dallas so pickup is free.
Old Feb 8, 2011 | 02:18 PM
g35man04's Avatar
CLUB MODERATOR
very nice!!
Old Feb 8, 2011 | 02:20 PM
ezpotato's Avatar
what all does it have? 2600 plus install seems more than i wanna spend. but depends on what it includes.
Old Feb 8, 2011 | 02:32 PM
http://www.importpartspro.com/st1blon.html
Either way you look at it someone is going to have to install it for you.
ezpotato's Avatar
http://my350z.com/forum/engine/28935...e-charges.html
found it... not a bad deal if i needed a new block honestly... i just dont have 3k...
anyone wanna buy my shortblock?
