Any local Motul dealers?
Old Mar 30, 2011 | 04:15 PM
  #31
BlueBOB's Avatar
Originally Posted by sexyrob
there was one guy on the thread I was following who was using motul and then tried another version and it got a little better then when he switched to amsoil his next BL test was clean. there were a couple of guys in that thread who had sub par motul results. It may have been something else though.
Yea, the OC problem with the HR motors can also be a factor in general. Which is why I always had the dealership do my oil changes. I brought the oil, they did the work... JUST in case
Old Mar 30, 2011 | 04:22 PM
  #32
jran76's Avatar
Cool, thanks. I think I am looking for something a little different as I explain above. I think there are better oils for protection (your Penzoil Ultra is probably better, and by all accounts one of the best for the VQ35), but I need something that provides more lubrication than your typical oil. The ester base aids in this. Penzoil won't state what is in the Ultra, so for the time being, is no good for me. I didn't want to get super technical as there are already enough threads about oils....
Old Mar 30, 2011 | 04:25 PM
  #33
sexyrob's Avatar
... think you mean revup there buddy but I know what you mean.
also jran you are completely right about the vvel and the new engine, dunno what I was thinking.
Old Mar 30, 2011 | 04:36 PM
  #34
jran76's Avatar
Originally Posted by PhGit
As for switching to syn I'd say just keep a close eye on it. I got a new engine in May 2009 (due to OC) and ran the default oil at the Firestone which I believe is a blend until November 2010. No consumption (that I noticed). I switched to Mobil 1 syn 5w-30 and 3 months later check oil light came on and I had no oil on the dip stick. Put in 4 quarts and got it in range. It just sucked down that Mobil 1! I check it every 2 weeks now as a rule.
I got some Mobile 1 10w-30 and will be trying that soon to see if it helps.
I will definitely keep an eye on it, but your Revup is much more notorious for OC than the vq37vhr. Mine has been going through about 1/2 a quart every 3000 miles.
Old Mar 30, 2011 | 04:43 PM
  #35
jran76's Avatar
I am sure that is what Chris meant (he had a revup). His fingers work faster than his brain sometimes.
Old Mar 30, 2011 | 04:45 PM
  #36
BlueBOB's Avatar
Yep!
Old Mar 30, 2011 | 04:47 PM
  #37
r1forever80's Avatar
With revup you dont have to do oil changes just add 4 qrts at oil change time since there is probly no oil in the pan. lol
Old Mar 30, 2011 | 04:49 PM
  #38
sexyrob's Avatar
:P lol true
Old Mar 30, 2011 | 05:07 PM
  #39
BeerViper's Avatar
Mobile one looks good too. at least in 0w-40
This is the only oil I've used in my [current] G - I've done UOA on every oil change - after autocrosses, track events, highway, city driving.
I change every 3k miles regardless of the period of time it takes (some changes have been 12+ months apart) and the UOA on my sample oil has been "very good".
Old Mar 31, 2011 | 05:41 PM
  #40
dubdub1's Avatar
reply
scareb performance in mansfield its owned by a guy named dan he is a dealer in motul fluids
jilljann1
Jul 21, 2020 08:12 AM
Jyounya
Sep 12, 2015 04:03 PM
AuAltima3.5
Audio/Video/Electronics
Sep 12, 2015 08:21 AM
Mikesta
Sep 10, 2015 05:14 PM
