Drag NHRA, IDRC, IHRA, NDRA
View Poll Results: Have you taken your car down the drag strip?
YES
36
48.00%
NO
39
52.00%
Voters: 75. You may not vote on this poll
Post up your best 1/4 mile ET/MPH
Old Apr 15, 2007 | 09:32 PM
  #61
GrayG35's Avatar
Originally Posted by trey.hutcheson
That's an excellent trap for the car and mods. Congrats.
thanks. i hope to break 13's and raise my trap after my next mod. the next mod im going with is going to be kind of a gamble but im thinking its going to work. I dont want to say what is is yet but if it works ill let you all know.
Old Apr 15, 2007 | 09:34 PM
  #62
IP05G35's Avatar
That certainly makes you the fastest all motor sedan, if not g35 period. Of course, that doesn't include ISMSOLUTIONS, but we never got a timeslip for his <12 runs.
Congrats. I know my car will never trap 105mph.
You might come close if you got 3.90 gears.
Old Apr 15, 2007 | 10:17 PM
  #63
cutiewolf's Avatar
2003 5AT
ztube/popcharger,UR Crank Pully,Megan Testpips,Hks Exhuast,1/2 spacer
sitting on 19s Volks GT7
The First time..i had 7 pulls
First Pull
+.7679 -----reaction
2.5422 -----60 ft
6.6491 ---- 330
9.9421 --- 1/8 ET
74.46 --- 1/8 MPH
12.777 --- 1000 ET
86.54 --- 1000 MPH
15.1501 ---1/4 ET
95.53 ---1/4 MPH
Last pull of the day and the best
+ .3360 -----reaction
2.2890 -----60 ft
6.1789 ---- 330
9.3459 --- 1/8 ET
76.79 --- 1/8 MPH
12.0710 --- 1000 ET
89.80 --- 1000 MPH
14.3551 ---1/4 ET
98.86 ---1/4 MPH
Old Apr 15, 2007 | 11:31 PM
  #64
IP05G35's Avatar
Please list your year, model (coupe or sedan), transmission and list of mods. Posting just your timeslip isn't that helpful.
Old Apr 15, 2007 | 11:38 PM
  #65
Crappyday's Avatar
Body type: 2003 Coupe
Transmission: 5AT
Modifications: Z tube popcharger
Track location: Houston Raceway Park
Conditions:
60': 2.115
ET: 14.148
MPH: 98.34
Old Apr 15, 2007 | 11:48 PM
  #66
marty315's Avatar
Transmission: 5AT
Conditions:
60': 2.115
ET: 14.148
MPH: 98.34
__________________
03 Diamond Graphite G35c 5/AT ** Mods Coming **
Glad to hear you guys had a good time. Sorry I couldn't make it, crawfish and dos xx on a day like this were just too tempting. Glad to hear the car can get into the low 14's. Now just gotta get your spacer, your high flow cats and we'll see if you can make sub 14.
Old Apr 16, 2007 | 01:44 AM
  #67
ZXiMan2's Avatar
1/4 mile times....
Thanks, but like you, I just had to do a motor transplant (long block) and it was an "out of pocket" expense
It was using over 2 quarts of oil between oil changes and then it just threw a rod or spun a bearing on the bottom end. Unfortunately for me, I change my own oil and lost my reciepts from where I bought my cases of oil. Sucks to be me!
$9,800 later....
I am back in business!
However, now my car seems a bit lazy from 4,000-5,500 rpm or so. My motor only has 500 miles on it, but it seems much more responsive on the bottom and pulls HARD after 5,500 rpm...
I dyno'd @ 21st Century Muscle Cars in Carrollton, Texas last spring (old motor and with close to red line pinging problems)... result was on 93 octane: 262hp but my torque was a paltry 221ftlbs (SAE corrected)...
Here's where things got interesting....
I added a few gallons of racing fuel, drove the car 20 miles hard and came in and did another pull on the dyno... result: 277hp & 242 pft (SAE corrected). No more pinging on the dyno. Torque was ALOT higher and could be felt in the seat of the pants on my pre dyno drive. I have a feeling the knock sensor was making the computer retard the timing quite a bit.
The weird thing about my car, is that the horsepower curve never fell off up to red line (on both of the runs). It just kept climbing until it hit fuel cut off... A/F was pretty good but was just a hair lean (13.2-13.7) for the last couple hundred rpm (could be adding to the pinging problem). I need a tune for sure.
Oh, and by the way, the 3.917 gears were worth a solid 2 mph in the traps (and almost half a second reduction average in 1/4 mile times). I've run a bunch of 13.50's @ over 105 mph with so so 60ft times. The gears make traction a problem in 1st and 2nd gears (especially when shifting 1-2) on the 6MT. The Kumho SPT275/30-19s are VERY VERY sticky (especially when new), and VERY wide for a 275. They are the widest 275 width tire I have ever seen. They were half an inch WIDER than the DZ101 275/30-19s I had on there before. They made a huge difference in launch. I have no doubts I could run high 12's with some traction (ie:drag radials) and a low 60ft time.
Like yourself, I am hoping the new motor will have the same umph of my old one... driveability sure seems improved, which makes me think torque may be slightly higher. I will re dyno after I get around 3,000 miles on the new motor. I will also be hitting Texas Motorplex or Alamo Speedway sometime after that to get a few new runs in...
chinee
Jun 10, 2024 07:48 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
wojowojo16
Jul 27, 2015 09:57 AM
