Drag NHRA, IDRC, IHRA, NDRA
Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )
Old Nov 17, 2009 | 11:30 AM
  #376
It's a G thing's Avatar
Hey guys. Not sure how up to date these lists are, but maybe I can join. I took my completely stock G37s out to the track a couple days ago with only 1500 miles on the car to see how she would do. I only got 2 runs in this night.
The best was a 13.73@103.43.
1. 2009 G37s - Coupe
2. 6 speed manual
3. Stock street tires (Potenzas)
4. N/A
5. No nitrous
6. Stock motor
7. Palm Beach International Raceway (Moroso) - South Florida
8. Temp was 70F, done at sea level
*Video*
Old Nov 17, 2009 | 05:58 PM
  #377
1bad20b's Avatar
i wonder what is the fastest 1/4 mile for a G
Old Nov 17, 2009 | 06:46 PM
  #378
03threefiftyz's Avatar
I think Intense has it right now, but blackbird has more mph. Both are in the 11.0x's.
Old Nov 17, 2009 | 07:40 PM
  #379
1bad20b's Avatar
that's nice. i wonder how much power they are putting down
Old Nov 18, 2009 | 01:43 AM
  #380
Intense has made over 900whp on a dynojet (Probably more at this point), but I doubt they were anywhere near that for that run. They are also in AZ (high DA's).
Blackbird made ~640whp on a dyno dynamics (or mustang dyno can't remember), which would be in the ~725whp area on dynojet when he went 134mph. His car is also quite heavy. That power level with good traction should be good for high 130's logic would think. With a 1.5 60' he should be able to go very low 10's.
Old Nov 18, 2009 | 12:44 PM
  #381
str8dum1's Avatar
forgot to post here
1. Year and Model (trim) of car: 2003 G35c
2. Auto or 6spd: 6sp
3. If you were running Street tires, Drag Radials or Slicks: DR's
4. What type of Turbo or SuperCharger kit you are running: Vortech
5. What Shot of Nitrous: 0
6. If your motor is Built or not.: No
12.3603 @116.55 with a 1.9179 60'
8.0698 1/8th @ 91.48mph
That was my best run of 2 (still bogged a little off the line), busted axles on 3rd pass. Too bad I wont get the chance to make an 11s pass anymore still had another 2 mph in her with a better launch.
http://my350z.com/forum/7806953-post1958.html
Old Nov 19, 2009 | 07:44 PM
  #382
INTENSEPOWER's Avatar
Hellos,
I just PM'd Trey to update this thread with our time (almost 2 years ago now!)
11.00@129mph (~735whp)
1. 2004 G35 Coupe
2. 6spd
3. Drag Radials
4. PowerLab 76S
5. No nitrous
6. Pistons, rods, valve springs, cams, standard ARP headstuds (stock crank, stock headgaskets)
7. Speedworld
8. DA=3989
PowerLab 76S kit (modified standard GT35R kit)
Drag Radials
Drive Shaft Shop
Stock Sleeves
Stock Crank
Stock Headgasket
Standard ARP Head Studs
PowerLab return fuel system
PowerLab plenum spacer
VeilSide Fortune Wide Body
Intensepower cage
Full interior
Full Stereo
Full weight + driver + stereo + interior = 3800lbs+!
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/g7d7L_z2XOA&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/g7d7L_z2XOA&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Nov 21, 2009 | 05:06 AM
  #383
allstockg35's Avatar
14.269@100.61mph
2.195 60ft
1. 04 Coupe
2. 6spd
3. Street tires
4. Bolt-ons, See sig for mods
7. Sacramento Raceway
8. Calculated DA -981 ft, not sure if this is correct, seems kinda low.
Temp: 40 degrees
Humidity: 86%
Track elevation: 100 ft
Pressure: 29.85
Attached Thumbnails Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )-img005.jpg
Old Nov 21, 2009 | 12:33 PM
  #384
Originally Posted by allstockg35
14.269@100.61mph
2.195 60ft
1. 04 Coupe
2. 6spd
3. Street tires
Temp: 40 degrees
Humidity: 86%
Pressure: 29.85
-981 is correct.
Old Nov 22, 2009 | 03:16 AM
  #385
Is anyone updating the list?
Attached Thumbnails Top 25 1/4 Mile Times For ( TT, ST, SuperCharger, Nitrous, Bolt-ons, Stock )-bob-s-race-results.jpg
Old Nov 22, 2009 | 07:09 PM
  #386
str8dum1's Avatar
^man that care in the right lane musta just been spinning thru 3rd
Old Nov 22, 2009 | 08:14 PM
  #387
ttrank's Avatar
Grocery getter
I ran a similar time with a trap of ~125. Traction was nowhere to be found.
Old Nov 23, 2009 | 12:11 AM
  #388
I don't think he was spinning.
Old Dec 2, 2009 | 10:08 PM
  #389
smitty89's Avatar
1. Year and Model (trim) of car: 2003 G35 coupe
3. If you were running Street tires, Drag Radials or Slicks: Drag Radials
4. What type of Turbo or SuperCharger kit you are running: Test pipes-Invida exthust-
Power pully-Short Ram
14.5 @92 with 5200 DA
Old Dec 3, 2009 | 11:50 AM
  #390
I wonder what time that would be at sea level?
