Drag NHRA, IDRC, IHRA, NDRA
whick fuse is it?!?!?
Old May 31, 2008 | 04:26 PM
Aced16's Avatar
i know there is a fuse you pull so you can hold the brake and gas for a burnout, and i have searched with no avail! can someone PLEASE help me!
Old May 31, 2008 | 04:58 PM
officerdbag's Avatar
I dont remember which one it is.. but its located by the gas and brake pedals.. Another guy with a G told me about it and he said it helped shaved 0.2 seconds off his 1/4 mile.
Only drawback he said was that your brakes can lock if you press them a bit too hard after the drag run.
Old Jun 1, 2008 | 05:02 AM
Skaterbasist's Avatar
Retired SuperMod
Its in the fuse box near the clutch. If I remember, it says something like "Brake Lamp".
Ninous26, I don't think it takes away ABS. The only drawback is the fact that your brake lights wont light up. So you just have to be a little extra careful with the guy behind (or if you're getting smoked, then it doesn't matter anyway ).
Old Jun 1, 2008 | 12:02 PM
DaveB's Avatar
Or you can pop off the center console and disconnect the VDC sensor. It will turn off stability control and traction, but leave the ABS. When I disconnect this sensor, I can do sitting burnouts quite easily. Haven't tried it at the strip though. I really don't think it help me much because I have no real need to do a burnout since I don't have drag radials or slicks. Doing a burnout on street tires is worthless and will release oils from the tires and make them slick. Only the drag racing ignorant do burnouts at the strip on radial tires.
Old Jun 1, 2008 | 08:05 PM
Retired SuperMod
^^ on street tires, like DaveB implied, the only thing you really need to do is "spin" the tires for a second before you get to the line (around the water box!). Just to clean off anything of the tires.
Burnouts are not necessary unless you have DR's/slicks.
DaveB's method looks a bit more complicated than just pulling the brake lamp fuse.
Old Jun 1, 2008 | 10:40 PM
Aced16's Avatar
i have my fuse door right infront of me and the only fuse there is a 10amp "stoplamp" fuse. pulled it and that didnt work does anyone have a pic of which fuse?!?!? i have DR's on the way and will need to pull it and DaveB's just seems like alot of work lol any ideas????
PS - the "stop lamp" fuse is under the catagorie marked BAT second from the right on the bottom row
Old Jun 2, 2008 | 01:38 AM
DaveB's Avatar
It only takes me about 15 seconds to access the sensor. Removing the plug is a bit hard though and that takes about 30 seconds. For a 6MT, it may be slightly harder or about the same. The picture is misleading and at least with the 5AT, you don't have to remove the center console. I simply remove the shift know, lift up the top console part, disconnect the sensor, reassemble. 1 minute tops. The advantage to disconnecting this sensor is that you still have ABS and full functioning brake lights.
Old Jun 2, 2008 | 10:13 PM
Aced16's Avatar
is there a DIY for getting to it? i have a 6mt btw, THANKS DAVE B!
Old Jun 3, 2008 | 12:50 PM
98intrigue's Avatar
Where's the DIY on how to do a burnout? I don't know what to do...
Old Jun 4, 2008 | 10:52 AM
Aced16's Avatar
gas+break=burnout i know how to do a burnout ryan, i just want to know which fuse to pull and howcome you dont go to OSW ne more? i have seen you vids before, and thats one SWEET g!
Old Jun 4, 2008 | 10:57 AM
trey's wife's Avatar
My horns hold up my halo
Does anyone remember what thread Trey used to talk about this? I have no clue because it has been so long.
Anyway the jist of it was that we tried pulling the fuses and that didn't work for us like it should have. We ended up popping the hood and unhooking about 5 wiring harnesses in the front near the driver's side. If you can find his thread about it, I believe he put up pictures. w0ady was at Sharif's when we finally got it to work, so there is a *chance* he remembers.
Old Jun 4, 2008 | 11:21 AM
AboostedG's Avatar
Here's the thread when Lyndon and myself were there at Sharif's with you all...
https://g35driver.com/forums/general-tech-questions/144095-burnouts-vdc-fuse-brake-fuse-abs-fuse.html
Here's another where Trey talks about the "Stop Lamp Fuse"...
https://g35driver.com/forums/g35-sedan-v35-2003-06/186369-05-rwd-fuses-fusebox.html
Old Jun 4, 2008 | 11:41 AM
Thank you dear! It is still very early for me. LOL
Old Jun 4, 2008 | 11:56 AM
AboostedG's Avatar
LoL, it's all good, you're welcome.
Old Jun 4, 2008 | 09:58 PM
Aced16's Avatar
Thank You All For The Help!
