Drag NHRA, IDRC, IHRA, NDRA
whick fuse is it?!?!?
Old Jun 6, 2008 | 01:32 PM
98intrigue's Avatar
Originally Posted by Aced16
gas+break=burnout i know how to do a burnout ryan, i just want to know which fuse to pull and howcome you dont go to OSW ne more? i have seen you vids before, and thats one SWEET g!
Ehh...I don't do much with the car anymore.
Old Jun 7, 2008 | 10:10 PM
Aced16's Avatar
thats depressing, you drive one of my fav G's! hopefully you will go out one day so we can see it run!
Old Jun 7, 2008 | 10:17 PM
98intrigue's Avatar
PM me when you go. Work is getting horribly slow, so maybe I'll have off on a Wed/Fri. It would be convenient since I'm running my DRs on the street right now. It looks pretty sick
Old Jun 14, 2008 | 03:53 AM
Skaterbasist's Avatar
Retired SuperMod
Alright. Just came back from the track. I can confirm its the "Stop Lamp" 10A fuse near the clutch.
It was my first time with the DR's, and I did about 8 standstill burnouts of about 4-5 seconds each
Took me 1 minute to get the fuse out.
PS. The VDC, Slip, & ABS light will go on.
Old Jun 15, 2008 | 04:56 PM
Sylvan lake V35's Avatar
Does this completely disable the VDC as well? I may have to start my own thread but I thought I would try here first. I ran drag radials and they are much shorter(less overall diameter) than stock tires. My last time out when I would shift my car car would briefly stumble I wonder if its the VDC kicking in? The switch is off but I have heard it comes on in extream situations.
Old Jun 16, 2008 | 01:13 AM
Retired SuperMod
Pulling the Brake-Lamp fuse should completely disable the VDC too. I had absolutely no trouble burning rubber at the water box
Old Jun 16, 2008 | 12:39 PM
Thanks I will give it a try after I get a new axle in!
G35-R
Nov 7, 2015 01:21 PM
Learned Hand
Oct 1, 2015 09:02 AM
yosip1115
16
Sep 28, 2015 04:14 PM
JLee301
Sep 25, 2015 08:46 PM
2014g35x
Sep 11, 2015 07:53 PM
