Drag NHRA, IDRC, IHRA, NDRA
...Top 25 1/4 Mile Times...
Old Jul 15, 2013 | 07:21 AM
  #46
Dsskyline's Avatar
Originally Posted by Shurik355
^^^ what are your mods??? Is your G boosted??? That's a pretty impressive time and power for an 04 sedan if it's only bolt-ons!
No that is NA power. I used to be boosted going SC next yr. I drive a coupe there is a vid in that link.
JWT S1 cams
Kinetix Velocity
UDP pulley
3in MAF
09 Maxima TB
PPE longtube headers
Custom exhaust using a IPL muffler
transgo shift kit
high stall 3k torque converter
osiris tune 307/260
mods from the video
ported manifold
3in MAF
ART pipes
momentum headers
invidia gemini exhaust
UDP pulley
transgo shift kit
osiris tune 260/235
Old Jul 15, 2013 | 12:49 PM
  #47
bigc's Avatar
Wings Nation
Originally Posted by Dsskyline
What!! You went big this time around. Congrats.
Thanks man. Lucy's heart started giving out last fall so I sold off a bunch of stuff and went with a TT setup. How are things on your end?
Old Jul 15, 2013 | 05:40 PM
  #48
Dsskyline's Avatar
good so far just running NA at the moment. I miss boost N2O only lasts until the bottle is empty.
Old Jul 15, 2013 | 08:59 PM
  #49
herrschaft's Avatar
Updated
Old Jul 27, 2013 | 04:01 PM
  #50
Citacel's Avatar
1. Year and Model (trim) of car-----2005 G35 Coupe
2. Auto or 6spd--6MT
3. If you were running Street tires, Drag Radials or Slicks--MT DR's
4. What type of Turbo or SuperCharger kit you are running--Momentum Performance ST
5. What Shot of Nitrous---N/A
6. If your motor is Built or not.--Built bottem end stock heads and cams
7. Drag strip name/location (optional)--Gainesville Dragway FL
8. Conditions, preferably a calculated DA (optional)--around 82 deg.
http://http://youtu.be/kvzV2ZabX64
first time at the track since i built the engine i could not get traction at all first and second gear spinning like crazy
i run a better time when i was at 8 psi and just 421whp l oh well i guess i need more practice and change the drag radials to slicks
Old Jul 27, 2013 | 04:42 PM
  #51
unvmyg's Avatar
This is my best 1/4 time. 2nd time attending drag races
Things we need from you guys.
1. Year and Model (trim) of car-----2004 G35 Coupe
3. If you were running Street tires, Drag Radials or Slicks--street
4. What type of Turbo or SuperCharger kit you are running--Vortech S/C SI Trim 3.25, cams, headers, art pipes, MD TDX2
6. If your motor is Built or not.--Stock
7. Drag strip name/location (optional)--Sonoma Raceway, Sonoma, CA
Attached Thumbnails ...Top 25 1/4 Mile Times...-img_2802.jpg
Old Jul 28, 2013 | 11:54 AM
  #52
WhosUrBuddiee's Avatar
08 Harley Vrod 10.75@ 125mph
Old Jul 29, 2013 | 10:31 AM
  #53
herrschaft's Avatar
Updated
Old Aug 9, 2013 | 01:17 AM
  #54
unvmyg's Avatar
New run with new upgrades...
I'm car #15
1. Year and Model (trim) of car2004 G35 Coupe
3. If you were running Street tires, Drag Radials or Slicks--ET Streets
4. What type of Turbo or SuperCharger kit you are running--Vortech V2 Si trim, 2.87
5. What Shot of Nitrous--n/a
Attached Thumbnails ...Top 25 1/4 Mile Times...-img_2863.jpg
Old Aug 9, 2013 | 09:35 PM
  #55
herrschaft's Avatar
^Added
Old Aug 26, 2013 | 08:54 PM
  #56
nova15566's Avatar
NA RUN- (had nitrous issues and decided to just run na after that)
With a passenger
5at Stock bottom
BC stage 2 cams
4in intake/maf (made by me)
ported intake mani
Full bolt ons
street tires (nt555r 100 tread wear street tires that kept spinning... 15x8 welds)
Rockingham Dragway, North Carolina
Fuel= E85 blend (70%)+100% Methanol do3 nozzle.
Old Aug 30, 2013 | 06:56 PM
  #57
Jtrain's Avatar
WIsh I knew where my slip was. I'd be right at 10th.
I was on some older thread.. Guess I'll just go out and do 11 seconds again sometime when my swap is done.
Old Aug 30, 2013 | 09:37 PM
  #58
herrschaft's Avatar
Are you saying you posted a time slip for an 11 second run somewhere else? Your currently on the list at #9.
Old Oct 7, 2013 | 08:58 AM
  #59
Madelinot's Avatar
11.68 @ 122.5
1. Year and Model: 2004 G35 Coupe, daily driven
2. 6MT
3. 305s Drag Radials (Toyo Proxes R888)
4. APS Twin Turbo standard kit (installed way back in 2005)
5. What Shot of Nitrous: N/A
6. Built Motor, stock heads and cams, 20 psi of boost.
7. Drag strip name/location: Napierville Dragway
8. Conditions: sunny, 70F, light headwind
Old Oct 7, 2013 | 09:19 PM
  #60
herrschaft's Avatar
^Nice time, added.
