Grinding Gears
Old Jun 7, 2006 | 09:26 AM
JuicedAthletics's Avatar
Grinding Gears
Ive been grinding 2nd gear a few times recently. Tracking my car...
Do I look in the differential oil for shavings or do I look in the tranny oil? Im going to replace both oils, I just dont know which one I would notice the shavings in. Also, How much would it be for a new gear set?
Im all done trying to drag this car, its really not meant for it at all...
Old Jun 7, 2006 | 09:32 AM
ISMSOLUTIONS's Avatar
This car is definatelt meant for dragging...you have to build it that way and know how to drive it that way first
Grinding gears is a transmission thing...
Changing your gears in the diff is about a $1,500 item...
Rick
Old Jun 7, 2006 | 10:13 AM
Rick
I see your point..
Ive scratched 2nd gear heard about 3-4 times. Is there a way to check for premature wear? I thought that by changing the fluids I might notice something if it was bad. I mean it shifts fine. I just dont want problems down the road...
Old Jun 7, 2006 | 10:36 AM
I see your point..
Without running it through a filter, not really. Also, I am not sure if the drain plug is magnetic or not - if it is, you'll see the shavings there.
Traaditionally - I like removing the pan completely when doing a change like that to get the real story.
Rick
Old Jun 7, 2006 | 12:22 PM
babylef's Avatar
I see your point..
^ why don't you do oil analysis?
Old Jun 7, 2006 | 03:19 PM
gnbtween's Avatar
I thought the gears are constantly meshed, and that it is
the "synchros" (triple-cone) doing the grinding?
Old Jun 7, 2006 | 03:30 PM
watsgoodG's Avatar
dont feel bad i had the same problem i grinded the crap out of my gear yesturday and i only have 1500 miles on the car...the tranny is prob equivalent to 60000 miles now.
Old Jun 7, 2006 | 05:10 PM
samualcc's Avatar
I dont think so...
I think you guys are under estimating the ability for the transmission to take a hit every now and then. I don't think you will shorten the life of your transmission by any great degree by grinding a gear every now and then.
If anything, syncros would be the first thing to go in a manual trans, especially if you are in the habit of skipping gears on an upshift
Just shift in squence when you are downshifting and rev match whenever possible and I think your clutch and trans will live on quite a while.
Old Jun 7, 2006 | 07:36 PM
perfectmax's Avatar
Wink
A quick 1-2 shift in the G sometimes leads me to a gear grind. I have driven stick for over 10 years and for some reason only have this problem with this car. I miss 2nd a lot! 16k miles and no problem. I wouldn't really worry about it.
Old Jun 8, 2006 | 08:25 AM
watsgoodG's Avatar
What is syncros? I dont know wat it is ive driven manual before and when i started driving this car i felt like i had to learn all over again...i drove an 06 rsx and the trans shifts sooooo easy and smooth...where did infinity go wrong now i starting to hear like a rubbing noise when i let the clutch go...
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
alinero718
Sep 27, 2015 09:35 PM
Since 1983
Sep 19, 2015 10:26 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
