Stock Clutch Position?
Old Jun 19, 2006 | 09:33 AM
dartmouth01's Avatar
Hi All,
I want to return my clutch back to the stock position (lowered it a while back with the clutch mod), but I can't remember how many turns I lowered it. Can someone tell or show me how to measure the clutch pedal so I know its in the stock position? I remember seeing a page out of a manal posted, but I can't find it anymore....
Thanks
Old Jun 19, 2006 | 02:35 PM
Bobalude's Avatar
believe its 1mm of freeplay?
that is go until it has absolutely no resistance, and there's a point where there is minor resistance (you can feel if you move it slowly) that increases as you press the pedal more.
Old Jun 19, 2006 | 07:29 PM
Does that count for the free play that is already there (ie the pedal where it joins to the threaded shaft is a pin joint, and theres already some free play in there.....)
Thing is moving the clutch pedal on that threaded rod does not make the rod start moving sooner or later when you're pressing on it, it just means there is more travel of that rod, since the pedal is further out. So I don't quite understand the freeplay aspect, because I noticed the freeplay is the same in stock and the modified position I have it in now....
Old Jun 20, 2006 | 03:01 AM
Bobalude's Avatar
umm... i know that when im down there testing it with my hand, there's about 1-2mm of total free play w/ no resistance. then it hits some resistance, and then a little farther down it requires quite some effort to depress. That is just the pedal. i have not modified it at all, completely stock.
Old Jun 20, 2006 | 08:59 PM
Thanks Bobalude, I've moved it out and I still have that 1 mm of freeplay, so I'm not sure thats the deal. Right now my cruise control switch is only 1/2" threaded in, I backed it out because I had screwed it in further when I did the mod.
Does anyone have the 05 service manual and can perhaps post that page that shows the clutch adjustment? I'd download the manual from the pay site, but I dont have a fast connection right now....
Muski_G
Dec 1, 2023 11:11 AM
Daniel k.
Nov 3, 2015 09:52 AM
zcherub
Aug 30, 2015 05:04 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
