Clutch pedal squeaky
Old Jun 24, 2006 | 09:39 AM
CalRSX07's Avatar
I just got my car, 03 coupe with about 45k mi on it... recently i've noticed the clutch pedal is squeaky when i push it up and down... but there's no clutch slippage and it's not hard to shift or anything like that
anyone encountered this problem? is it just as simple as needing to be greased up a lil bit??
Old Jun 24, 2006 | 12:45 PM
stillen_i30's Avatar
hey, i just posted about this recently also. Just started noticing this issue as it became warmer the past few months. Some people suggested some grease, nobody else seemed to have the issue. Will be taking it into the dealer to have it checked out
Old Jun 24, 2006 | 01:45 PM
350gtcoupe's Avatar
i have 03 too and im at around 45k also and my clutch since it got warmer started doing the same thing...anyone know what how to fix this???
Old Jun 24, 2006 | 04:20 PM
Jining's Avatar
I also have an 03 coupe, about 45k miles as well. I also have the same problem... probably only requires a little bit of grease, let me know what the dealer says, im going in soon to try and get a few things replaced as well.
Old Jun 25, 2006 | 12:04 AM
98intrigue's Avatar
Mine has been squeeking for awhile now, too. I have almost 54k miles on mine.
Old Jun 25, 2006 | 12:14 AM
papagz's Avatar
i think the problem starts at 40k for these cars. mine was so insanely bad i couldnt live with it. just put some wd-40 and your good.
Old Jun 25, 2006 | 12:50 AM
CalRSX07's Avatar
is WD40 really the answer??
Old Jun 25, 2006 | 12:54 AM
papagz's Avatar
worked for me
Old Jun 25, 2006 | 04:10 AM
CB_Skyline_03's Avatar
where @ if you dont mind me asking? the actual pedal? slave cylinder (where it meets the fork)?
Old Jun 25, 2006 | 11:14 PM
Balzac72's Avatar
G SQUAD
This was the first thing that happened before I needed a complete transmission swap. I'm serious. It was performed under warranty, but the 03 cars have had major tranny problems.
Old Jul 14, 2006 | 10:05 AM
G35 Hokie's Avatar
I just purchased an 04 G35 coupe and I think I am having the same problem. The last 1" or so of travel pushing the clutch down and releasing it has a squeaking noise. No matter whether I do it slow or fast it's still there. I bought some WD-40 but when I get up under there I can't pinpoint exactly where to apply it? Can anyone let me know where the WD-40 needs to be applied to make this go away? Other than that, I love this car!
Old Jul 23, 2006 | 12:59 AM
CalRSX07's Avatar
so when i had it in at the dealership, i asked them to look at it and lube it to get rid of the squeak. well, they lubed it and the squeak went away... but the tech thought something wasn't quite right, so he inspected it and said the clutch needed to be replaced. so now i have a new clutch, free under warranty.
Old Jul 23, 2006 | 01:10 AM
GTT's Avatar
GTT
G35 Twin Turbo
I have 19k miles on my G right now, and I have this issue 7k miles ago. I just turn the music louder and u won't hear it. LOOL As a temporary solution
And sometimes my clutch paddles stick and I have to pull it out.
Old Aug 4, 2006 | 05:48 PM
gte843k's Avatar
Talking
My clutch has a slight squeeking noise pressed about 1/4-1/3 from the floor. IT doesnt' squeek from top all the way until about to the point that I just mentioned. I turned up the music and it seemed to go away....it's all in my head.....I thought..... I didn't think it was a serious problem so i never looked into it.
IT would be nice to know where to apply the WD40. That way, my music doesn't have an added squeeking noise when I press the clutch...hahaha
Old Aug 4, 2006 | 06:48 PM
6spG's Avatar
It's your throw out bearing. I took my 03 w/45,000 miles in last week to the dealer. They lubed up the throw out bearing and now it's fine. Everything was covered under warranty.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
jbmw002
Sep 10, 2015 12:54 AM
TheBay
Sep 3, 2015 03:27 PM
