Manual transmission whine when cold
Old Feb 13, 2007 | 03:34 PM
obender66's Avatar
Few people posted about whining 6MT when cold. Dealer had my G overnight to duplicate the noise and traced it to driveshaft. They will replace it (car has <2 months of warranty left), will be couple of weeks until part gets here from Japan.
Service rep said that "nothing will fail", it is simply comfort issue. I hope new driveshaft will fix the problem.
Old Feb 13, 2007 | 04:47 PM
nycsan87's Avatar
hey man i just wanted to know if you describe the sound and when you noticed it, how long and where it was comingfrom etc
i just want to see if the sound im hearing is the same
thanks
Old Feb 13, 2007 | 05:28 PM
obender66's Avatar
It's coming from under the car, not from engine bay. It was always there on cold mornings(I got G 2 years ago). Goes away after 10 minutes of driving, doesn't change with rpm and can be described as combination of whining and howling.
Old Feb 13, 2007 | 07:25 PM
liukai's Avatar
simliar sounds have been posted mulitple times, and many got new manual transmissions for it. I'm getting a new tranny. clutch, and flywheel installed this friday because of that sound all under warranty. infiniti doens't know for sure if that'll fix it, but i complained enough to the point where they are.
Old Feb 13, 2007 | 08:27 PM
bobshuai's Avatar
Your dealer is nice.
Old Feb 15, 2007 | 09:41 PM
redriderr's Avatar
I've been hearing that whine for the past 3 weeks. I hear it even after the car is warmed...I took it to the dealer to check it out and got the "thats normal speech." WTF?! Car has 66k miles on it and Im not sure if the tranny/diff fluid has been changed. Im going to have the fluid changed soon...I hope it stops the whine.
Old Feb 19, 2007 | 12:28 PM
liukai's Avatar
i just got a call from my dealership, and they traced it to the rear diff. So, my tranny will not get repalced. damnit!
Old Feb 22, 2007 | 03:07 PM
Dustifer's Avatar
i had the same issue with mine. I took it to the dealer, and they said it was my throwout bearing and clutch making the noise.... Heh. So i just ordered a clutchmasters stage 2 clutch and aluminum flywheel and had them put it in there and replace the bearing. Works fine now, but MAN that clutch grabs quick!
g.spot
May 9, 2016 10:54 PM
Jcruzg35
Sep 26, 2015 04:47 PM
