HELP!! SLIP and VDC Off
Old Sep 14, 2007 | 12:11 AM
g35ATX's Avatar
Clock spring is the one has 4 wires connected to the airbag.
Originally Posted by derek321
I see maybe it was the other code it trew which was C1109 ? What exactly is a clock spring ... i removed my entire steering rack and for a while my alignment was total **** where i could turn one wheel to the right and turn the steering wheel twice to the left!! i dont have warranty so this is all coming out of my pocket... i guess im gonna try and get it aligned and then try to clear the code ... will that help ... my car was in a collision also so that might have a big part in it
Old Sep 14, 2007 | 04:07 PM
derek321's Avatar
how exactly does the dealer reset the clockspring? and is that a hard code meaning will it erase if i disconnect my battery for a long period of time? is there a way of me restting the clockspring myself or do i need special equipment for that?
thanks guys for helping me out so much i really dont have money to take it to the dealer cause i just need to sell my car right now
Old Sep 16, 2007 | 11:01 AM
g35ATX's Avatar
Not the clock spring, there's a steering wheel angle position sensor that mounted behind the clock spring. If you remove the sensor then it will need to be reprogrammed. I've read with bad alignment, the sensor sees the steering wheel always at the wrong position then it would throw the SLIP and VDC lights off. We need the CONSULT-II tool from Nissan to reprogram that sensor. The procedure is very simple but I don't have any hook up with that kind of tool.
Old Sep 28, 2007 | 03:16 PM
g35ATX's Avatar
Just got the car back from dealer, they charged $105 for a 15 min job ...
The lights are gone now.
Old Jul 28, 2010 | 11:23 PM
rotor7vent2's Avatar
so if the clock spring is replaced, is that what fixes the button on the steering wheel? because i have both problems, the vdc light and the dead steering wheel
Old Jul 8, 2011 | 05:21 PM
draco1020x's Avatar
Sorry to revive an old thread but i am having this same problem. My question is tho, instead of going to the dealer to have the sensor reset, is it possible for Uprev to clear this? I was planning on taking my car to get tuned tomorrow and if they can take this out it would save me that trip to the stealership
Old Aug 6, 2011 | 09:26 PM
beniscooler850's Avatar
you cant do it through uprev but you can go to pepboys to do it they charged me 20 bucks and reset it
Old Aug 6, 2011 | 09:59 PM
856_reilly's Avatar
Pepboys are you serious???? They know how to do this? What exactly was going on with you car? If it's the same issue I'm having where my vdc, slip,ras lights come on after driving then maybe I will take it there while I stand over his shoulder!!!!! I said I will never let pepboys touch my car, but if they can reprogram it or whatever then maybe. So let me know bud!!!!!!
Old Aug 6, 2011 | 10:06 PM
I only went to them cuz my boy works there and he told me they could do the reset no problem. Well my vdc, and slip light came on after 30 seconds of driving and the brakes acted like they wanted to lock up and all of this happened right after we were changing out headers and we disconnected the steering from the knuckle and then he decided to spin the wheel and kept spinning, well lesson learned dont spin the wheel when its unhooked unless you want to buy a new clock spring and pay for someone to reset your steering angle sensor.
Old Aug 6, 2011 | 10:09 PM
856_reilly's Avatar
You had to buy a new clockspring because he spun it and it was disconnected from the rack?
Old Oct 27, 2012 | 11:09 PM
chlippo's Avatar
reviving an old thread, but my 03 G35 sometimes acts weird when its running and i take a right turn. It feels like a steering "lock" for a second or so then it goes back to normal. All the suspension have been checked and the steering box and fluid. No warning lights go on the dash when it does it. Might it be possible that it is the steering postion sensor? like having a bit of misalignment in it?
what do you think?
Old Apr 6, 2015 | 12:49 AM
Selaines's Avatar
Same problem here on my 06 after picking it up from the dealer for a replacing a bad tire. Both slip and VDC light came on, steering wheel went crooked, then the ABS light came on. Called them, they said, "oh, they must've forgot to reset that" now I have to take it back in. I understand I will not be charged because they failed to do it the 1st time. Hope that takes care of the issue as it is steering really weird.
Old Feb 22, 2016 | 01:31 AM
deeliciousqueen's Avatar
G35 coupe 6mt
Did dealer replaced any parts? or just a simple reset with CONSULT II that fixed the lights?
MThawkins86
Oct 24, 2015 02:07 AM
markbilo
Sep 30, 2015 01:33 AM
vamarris
Sep 26, 2015 12:56 PM
