Question for those with a 5AT.
Old Apr 20, 2007 | 01:06 AM
rookie's Avatar
Mine won't shift at WOT in D at 14lbs with my 19s on. Never tried leaving it in D with my drag radials. Dsskyline with the ST and Stillen VB it doesn't shift fast enough for him in MM.
Old Apr 20, 2007 | 01:59 AM
urban's Avatar
Mine shifts at WOT with a nice aggresive bump, I am pushing 12psi and generating 410rwhp and 400lbs of trq. I have an upgraded VB and TC from GT Motorsports, even in MM mode it chirps the tires real nicely.
Old Apr 20, 2007 | 02:02 AM
maj83's Avatar
lazy a$$
Originally Posted by Queenskid24
thanks for the input guys. I didnt think i was causing any damage to it by Powershifting and the ride is so much smoother so ill just drive like that all the time now.
what's powershifting?
Old Apr 20, 2007 | 02:07 AM
rookie's Avatar
I have the same VB you do. It does shift hella fast for an auto, I chirp my drag radials at the track.
I guess this would be not letting off the throttle between shifts.
Old Apr 20, 2007 | 01:49 PM
Jeff92se's Avatar
Red Card Crew
Damn that's cool (that the autoenginuity can read that! I need to fire that thing up!) and odd that it would reduce line pressure in MM. wth is the purpose of that? It should up the pressure!
Originally Posted by sloppymax
One thing I noticed with the autoenginuity is that line pressure decreases when switched from d to any manumatic gear. Even at WOT, it was lower in manumatic than allowing the tcm to control the shifts.
Old Apr 20, 2007 | 02:11 PM
sloppymax's Avatar
I had the same reaction. I thought it would increase for a firmer shift. I am just breaking the surface with the AE.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
migurus
Sep 5, 2015 09:39 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
