5AT owners!
Originally Posted by savefatkids
i drive hard also..is it normal for it to shift harsh? becasue i dont remeber it shifting harsh when i first got the car
Originally Posted by Q45tech
If longevity after 70k warranty is a concern the earlier you start ATF replacement the better.............aggressive driving needs at least an every 30k replacement.........or you'll start seeing problems after 100k.
Remember AT cost $4,000+
Originally Posted by mike281
i get the hard shifts in manual mode too especially from 2nd to 3rd but only sometimes. It's weird like if i shift at a certain point and let off the gas it shifts really hard. It has done it from day one from what i can remember and I bought it new. anyone else have that problem?
the 2nd-3rd firm shift is characteristic. it's probably a good thing (easier on the tranny).
my tranny is super smooth in full auto (D) and fairly smooth 90% of the time in MM mode.
23k miles.
don't put anything other than matic-J fluid and don't over or under fill. full flushes are recommended every 2 years or a drain and fill every year.
23k miles.
I have an 05 A/T and i had my radiator changed, the idiots who did it didnt replace the fluid with the J-Matic the car takes..... I found that my shifts between 2nd and 3rd on manual mode are really rough, almost like a kick... I just had my tranny flushed and it has smoothed away. My fluid was almost a maroone color when they had it flushed and guess what.... my tranny only has 6,800 miles! Turns out the other mechanic put some walmart fluid in the car and it mixed in nasty with the J-matic and was causing a mess. Regardless $250 to flush, $110 on 12 quarts of fluid from dealer a lot better than $4000!.
