LSD questions.
Old Jun 22, 2007 | 01:37 AM
cipriopt's Avatar
LSD questions.
Does installing an Limited Slip Differential make such a big difference in handling tha car in corners? Is it really worth 12 hundred?
I need some opinions and reviews from someone who has it.
Old Jun 22, 2007 | 05:12 AM
redlude97's Avatar
the short answer is yes, but it depends on the LSD you are installing and how much driveability/noise you are willing to deal with for the added performance
Old Jun 22, 2007 | 12:33 PM
dklau33's Avatar
If you don't take your car to the track be it drag, road course, auto-x the cost of doing a mechanical lsd probably isn't worth it. But if you do I would say it is quite worth it and almost a necessity.
Old Jun 22, 2007 | 12:36 PM
savefatkids's Avatar
can someone help me out? i have a 5at with no lsd.. could i just get an lsd off a 350z? or would it be better to just go for the nismo lsd?
Old Jun 22, 2007 | 01:25 PM
helldorado's Avatar
You'd be best off with a Quaife. Its a drop-in for the 5AT open diff. Only other option is Cusco, or factory VLSD, but they require getting new axle stubs. Any other LSD would require sourcing a pumpkin from a 6MT to use as a basis.
Old Jun 22, 2007 | 05:45 PM
redlude97's Avatar
The LSD type you choose will depend on what type of driving you do and how much noise you are willing to live with. The stock LSD is noise free, but doesn't kick in until one of the wheels is spinning already which isn't optimal for track use. Other LSD's such as the nismo make alot of noises and aren't as driveable, do some research on here and my350z before you decide on anything
Old Jun 22, 2007 | 06:59 PM
cipriopt's Avatar
Ok, so what other LSD's are out there, besides the Nismo, and how do they perform?
Old Jun 22, 2007 | 07:11 PM
redlude97's Avatar
SEARCH! This isnt an easy question to answer, expect to spend 2-8 hours reading up on the different types of LSD's, their pros and cons, and lots of reviews before you make a decision, noones going to be able to tell you simply which ones to get
Old Jun 22, 2007 | 08:36 PM
cipriopt's Avatar
Thanks. I'll try.
G35 Driver FTW
seagrasser
May 3, 2022 09:43 AM
hurleyguys
18 Inch
Sep 9, 2015 12:24 AM
Shizzmaster2k
Engine - Exhaust
11
Sep 2, 2015 04:09 PM
myGspot
Drivetrain
Aug 11, 2015 11:58 AM
