How many of you 6MT drivers replace the clutch on dealer's advice
Old Oct 10, 2007 | 09:57 AM
dofu's Avatar
20 Year Member
Originally Posted by Klumzyee
btw the way i drive im expecting 30k tops for my clutch
I doubt anyone can abuse a clutch more than I have. And even with all that abuse, my clutch still made it to 50k, and it still had a good amount of life left.
Old Oct 10, 2007 | 10:06 AM
Blackbird V35's Avatar
I had the creaking noise in mine at 28k miles or so and the dealer told me to replace the clutch, i tolc them to go Fvck themselves. I found that if you take the slave cyl off and pull the rubber boot that holds the pivot fork out. Clean and lube the pivot fork area then the creaking is gone.
On that note, I still have the stock clutch, 63k miles with 5k miles on the vortech at 350-400whp with no slipping still, so dont fall for those dealer tricks
Old Oct 10, 2007 | 10:50 AM
kvangil's Avatar
Interesting and very helpful. Thanks! Stupid question of the day: Where is the slave cylinder located?
Old Oct 11, 2007 | 03:43 PM
OvaYahead's Avatar
Yup what blackbird said, plus lube that spring up top of the clutch pedal assembly. Thats where I found my squeaking from. A slipping clutch does not sound like a cat being stomped on.
Old Oct 11, 2007 | 10:42 PM
Still2Slow's Avatar
dealers advice, it wasn't slipping, but i saw it after it was out and it wouldn't have lasted much longer. throwout bearing was bad also
NemesisGee
Aug 11, 2015 07:10 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
vstypicals
Jul 20, 2015 10:55 PM
nascarbuff17
Jul 16, 2015 10:23 AM
driftsucky
Jul 15, 2015 12:38 PM
