Semi-emergency- Whats Wrong With My Clutch???
Old Nov 30, 2007 | 08:10 PM
06g35meister's Avatar
Well, i went out for some so called "spirited driving" and i came back and in the garage something felt off, no smoking or burning or any smell whatsoever, but whenever i depressed the clutch pedal it would go in easily, but was hesitant to come out. it felt like it engaged just fine, but that the clutch was not putting pressure back on my foot when i was releasing it. What could be wrong. Also, i took a video of it running when i was in the garage, dont mind the video, unless you think you can see something, but its the sound im worried about. Is my clutch fluid low? Im having it checked on monday, but im worried to even drive it, it felt different than any other time ive driven it...
and i love cold weather... MORE POWER with the intake! yay.
see video:
i tried to do it a lot, so done get annoyed. im positive it has something to do with the clutch, ALSO, if you know what it is, how do i fix it?
Kevin
thanks all
Old Nov 30, 2007 | 08:24 PM
**ahhhhhhhh Help Me Please!!!**
Old Dec 1, 2007 | 09:40 AM
g35rcr's Avatar
maybe a broken fingers on your pressure plate or your boiled your clutch fluid
Old Dec 1, 2007 | 10:10 AM
patman530's Avatar
you don't need to take it in just to see what level the clutch fluid is at... just open the cap and look. you might want to try flushing out the fluid a few times. i had a similar issue with my clutch and this fixed it.
https://g35driver.com/forums/showthr...lutch+sticking
Old Dec 1, 2007 | 01:08 PM
JTG35's Avatar
^+1 don't take it in. Do it yourself, its very easy. I fixed mine as well.
Old Mar 5, 2008 | 01:25 AM
By the way, this is a REALLY GOOD initial indicator that youre clutch is going out... mine went out about 500 miles later, just FYI to those who hear anything like this...
Old Mar 5, 2008 | 01:52 AM
redlude97's Avatar
your 06 clutch failed already? How many miles?
Dallsinghjr1
Sep 17, 2023 11:25 AM
jeffbdye
Jun 1, 2018 03:51 PM
AL8782
Oct 3, 2015 10:26 AM
Visionnn
Oct 3, 2015 05:16 AM
Learned Hand
Oct 1, 2015 09:02 AM
