MY DIY differential oil change
The oil in there was changed before but I did this for peace of mind and because I like my LSD
The magnetic drain plug did have metal shavings on it which I expected from reading up here but no metal shavings drained out.
The diff fluid change should be done every 30K miles or 2 years, whichever comes first.
Nice DIY pics QBridg. I did my diff fluid change a while back, and it's a lot easier than the oil change. I'm surprised you did this with no jacks and still have plenty of room under the car.
I had just bought jacks but since I could fit under it without them I did it like that since it was easier.
If you have a LSD and you like leaving 2 solid marks on the pavement launching then I suggest it's changed once every 6k-8k but I'm a lil crazy with it
