5AT gear ratio options?
Old Mar 6, 2008 | 03:49 PM
OCG35's Avatar
Originally Posted by DaveB
I just did a search and sure enough, there at least three accounts of 03/04 sedans and one coupe having CC issues after installing the 3.5 gears. The CC will work to about 72mph and if you try to accelerate with it on and go over 72mph, it will turn off and won't come back on until you restart the car.
I'll try it this weekend and see whats happens...
Old Mar 7, 2008 | 11:04 AM
Q45tech's Avatar
The fuel consumption will increase at roughly the rpm increase rate since at cruise the A/F is fixed so more revs per minute more fuel used per minute.
Obviously idle consumption won't change so it is never 100% purely linear but close.
I would expect a 4.083 to be ~~18-23% worse than stock on AT.
We've had a few 4.083 sub for 3.538 on early Q and the 15.8% tracks perfectly as to highway mpg within a few %.
Old Mar 9, 2008 | 09:02 PM
OCG35's Avatar
I have 3.692 (3.7) FD - yesterday I re-tested the CC... works as normal at any speed... I even set it at 50mph then accelerated with it to 90mph and it stayed... I'm not sure why the people DaveB mentioned had problems, but mine works exactly as it did with OEM 3.3 FD.
Old Mar 10, 2008 | 11:55 AM
Q45tech's Avatar
The question is how will the 15%-20% increase in highway fuel consumption say $450-$800 per year relate vs the few tenths gain in acceleration.
Will you be able to honestly sell [disclose your mods] the used car with dif gear or be forced to return to stock ratio [cost to change].
In theory you are commiting emission fraud because the engine produces more emissions per mile due to burning more gasoline per mile......whether a court would see it that way is up to the judge?
Old Mar 10, 2008 | 12:10 PM
sliderg35's Avatar
You could create the same increase in emissions by simply driving faster - if you were going to get technical...
Old Mar 10, 2008 | 12:37 PM
pjames's Avatar
here's another question in the opposite direction, has anyone put shallower gears in? say a 3, or 2.8? for those of us less concerned with all out acceleration?
Old Mar 10, 2008 | 04:02 PM
OCG35's Avatar
I drive the car about 50 miles per month (sometimes less)... I have all OEM parts and will have everything replaced to OEM (if new owner chooses) when it comes time to sell... thanks for you concern though
prinny
Nov 22, 2015 11:07 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
