Clutch burning???
Old Mar 6, 2008 | 08:43 AM
DrewQ1's Avatar
Clutch Test??
Hey guys, I did my first track day this past weekend. Did horrible since it was my first time at the track.
The following day i was driving my car i smelled a slight burning smell, it came inside the car but not outside. But i only noticed the smell if say I was just cruising at slow speed in say 3rd or 4th in a residential area or parking lot where i may be in 2nd or in slow traffic i might smell it. lately i havent really smelled it that much as before. I can still hear the clutch chatter also.
What are ways to know if your clutch is bad? I have had manual cars before but i never ever had to have a clutch replaced in them.
Ive had the G for about a month now, and the clutch definately took some time to get used to. When i would always shift into 2nd i would always get a jerk but now i dont notice it anymore. and even the downshifts are smoother also.
Also i did search and it said one way to know if your clutch is going is when you shift the rpms drop for a little bit before it comes back up. But how much do they drop before it comes back up. RPM's already drop anyway between shifts but i am thinking i may be paranoid and think that it drops more than it should only because thats what i found out when i searched.
Thanks.
Any advice or tips to know what to look for and to tell
Old Mar 6, 2008 | 09:34 AM
hampton_25's Avatar
clutch test
The way that I test mine is to get in to say 3rd gear and stay at around 3-4k rpms, then lightly press on the brake while giving it alot gas at the same time. If your clutch starts slipping then more than likely you will need to replace it. I know that there are other ways, but that is the way that I test mine.
Old Mar 6, 2008 | 09:45 AM
DrewQ1's Avatar
O ok, so if the rpms are increasing and I am not going anywhere than thats a clue...I'll try that later.
Anyone else?
Old Mar 6, 2008 | 08:03 PM
DrewQ1's Avatar
anyone?
prinny
Nov 22, 2015 11:07 PM
Vqalexisz
Oct 14, 2015 12:48 AM
AL8782
Oct 3, 2015 10:26 AM
Learned Hand
Oct 1, 2015 09:02 AM
