changing rearend gears?
Old Mar 27, 2004 | 11:11 PM
KevinG35's Avatar
Anyone change out their rearend gears with a numerically higher set? My old car was a mustang and I changed the rearend a month after buying it. I went from 3.08s to 4.10s.
Just wondering if anyone has done this mod to their G. The way this engine revs, the car screams for gear change.
KevinG35
2003 Diamond Graphite G35 Sport Coupe, 5AT, Premium Pkg, Performance Pkg.
Old Mar 28, 2004 | 08:20 AM
vgrani1g35's Avatar
Re: changing rearend gears?
i had a mustang as well, and was thinking the same thing. i have been on this website for a while, and cant recall someone even mentioning it. i would like to know too...
Old Mar 28, 2004 | 10:03 AM
belerin's Avatar
Yes, do a search, there are some EVO gears for our cars. Also, search on my350z.com for the same thing. Was going to get them, but I already have enough difficulty keeping my tires to the road with the nitrous that the gears would make it worse.
’03 G35S 6MT, black/black:
-Zex n20 Kit 150-shot & Bottle Opener
-Amsoil Air/Oil Filters & Oil
-Digital Nitrous Pressure Gauge & A/F Switch/Gauge
-Pressure-based Bottle Warmer
-MSD Window Switch
Old Mar 28, 2004 | 12:13 PM
DaveO's Avatar
There's a high possibility that the cruise control will not work with a rear end gear ratio change.
DaveO - 2003 G35 Sedan / DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TS ECU / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Mar 29, 2004 | 09:25 AM
3point5SE_Auto's Avatar
there are some 3.90:1 gears out there for the Z. there are fitment issues on the non LSD G's. You need extra pieces for these. Also the Z roadster comes with 3.5 gear and that is a nice mix.
If you plan on FI'ing the car, I think that taller gears would be better as I am already exceeding my traction. From what I have been reading, 1st gear is nearly useless with the Vortech
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Goodyear F1 GS-D3's 225/55/17, Custom Intake Tube, HyperGround Kit, Magnaflow resonator.
Old Mar 30, 2004 | 11:49 AM
KevinG35's Avatar
what do you do about calibrating your speedo? In the stang tranny you had to switch out the speedo gear, what about the G35?? Is it handled with an ECU upgrade?
KevinG35
Old Apr 1, 2004 | 08:58 AM
as of right now, you can't do [censored], other than put a yellow sticky on your dash with say "+30%" or some such. Mine says "+2%" cause of my tires.
Old Apr 1, 2004 | 11:23 AM
protocav's Avatar
that's not true...many cars have the speed sensors on the tranny, but the G has them on the rear hubs. changing gears would have no effect, since it is the wheel speed (actual speed of the car), and not the driveline speed that registers on the speedo. changing anything outside of the hubs, like wheels and tires will effect the speedo.
Chad
Old Apr 1, 2004 | 12:00 PM
KevinG35's Avatar
are those sensors for the speedo or for the traction control system??
KevinG35
thewarden
Aug 30, 2015 04:00 PM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
Frostbite91
Aug 20, 2015 07:20 PM
linedr89
Aug 17, 2015 05:11 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
