04 G35 6 spd tranny fluid
Old Apr 7, 2008 | 12:00 AM
Joey7489's Avatar
04 G35 6 spd.
I tried to use the Service manual in the FAQ/DIY section, but the Manual Transmission segment of it does not work, ironic....
This is what it says in the owners manual :
"Genuine Nissan tranny fluid HQ multi 75w85 OR API Gl-4 Viscosity 75w-85 or 75w90"
Is it ok to run a Mobil 1 Synthetic 75w-90 gear oil. It says on the back "Meet and exceeds API GL-5."
Is this what the tranny calls for? Owners manual says nothing about Syncromesh or ATF.... hmmmmm
Hopefully someone can help
Thanks
Old Apr 7, 2008 | 12:05 AM
Sponger's Avatar
6MT Brembo Coupe
Can't use the GL5 in the 6MT, only in the diff.
Old Apr 7, 2008 | 12:09 AM
Joey7489's Avatar
What should I use?
I dont want to buy it directly from Infiniti because its $19.80 a quart. Talk about bull****ttt..
Old Apr 7, 2008 | 12:25 AM
g35ctuner's Avatar
use royal purple
Old Apr 7, 2008 | 12:27 AM
partyman66's Avatar
Originally Posted by Joey7489
What should I use?
I'm a big fan of aftermarket fluids everywhere, but in my tranny I just ponied up and bought the right stuff from the dealership. These cars are known for tranny problems being more common than in other cars.... so you probably don't wan't to risk it with a weird fluid. The recommended viscocity is a very strange one anyways, and you won't find it anywhere in any other oil manufacturer. You can mix 2 different weights together though to get close to the OEM recommended 75/85, but it's still just easier to spend a little extra and go with the dealer stuff.
You might get it a few bucks cheaper if you go to Nissan and buy the Manual Tranny fluid for a 350Z... they use the same transmission as us.
Old Apr 7, 2008 | 12:32 AM
Joey7489's Avatar
Alright sounds good.
Thanks for the help
Old Apr 7, 2008 | 02:05 AM
boomergt's Avatar
I use the Amsoil Synthetic Manual Transmission and Transaxle
Gear Lube 75W-90 API GL-4 (MTG)
Works great..
Old Apr 7, 2008 | 09:43 AM
gunluvS14's Avatar
why not Redline MT-90?
its GL4
Old Apr 7, 2008 | 10:33 AM
lov3rboy408's Avatar
+1.. spend couple more and get the infiniti tranny fluid
if the car love to drink heineken.. why u feed coronna!
Old Apr 7, 2008 | 11:22 AM
V35 Skyline GT's Avatar
6MT Coupe
Works great..
True that!! Shifts are smoother. OEM dino way over priced and is the Corona...lol
Also use, Severe Gear SAE 75w-90 GL-5 in diff.
Amsoil FTW!!
Old Apr 8, 2008 | 12:57 AM
Sponger's Avatar
6MT Brembo Coupe
A 50/50 mix of Redline MTL and MT90 (GL4) is going in when I have time.
Old Apr 10, 2008 | 05:45 PM
jabrother's Avatar
Redline Mt90 should be the best, going to put it in when I have time. Anyone know how hard it is to change out the gearbox oil??
Old Apr 16, 2008 | 05:55 PM
partyman66's Avatar
It's cake. Just need to be able to get the car up high enough so that you can get under it and also have it be somewhat on a level plane so that you can accurately refill it until the fluid drains out of the fill hole(which would not be as accurately done if the car was on a huge incline such as it would be with only one end of the car up on ramps).
My driveway is on a fairly decent hill, so I just drove my car up on ramps where the ramps were facing down the hill, that way when I drove up on the ramps, my car was basically parallel to flat ground.
Old Apr 23, 2008 | 04:26 AM
yogi41's Avatar
Hey I was wondering when you usually change the tranny fluid... i'm right at the 60k mark and the service manual just says inspect it.. thanks
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
NemesisGee
Aug 11, 2015 07:10 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
Karnicle
Jul 23, 2015 05:08 AM
