wierd clutch pedal
Old Jul 15, 2008 | 11:53 PM
CreativeDesignZ's Avatar
wierd clutch pedal
Ok so Recently i have noticed more that when i first start my car i dont need to move the clutch pedal in that much...maybe only 1 or 2 inches, then after driving it for a while the pedal seems to "raise" itself and i need to push it down another 2 inches or so, liek the "play" in the top goes away and it becomes stiffer, sooner. Tonite i was just leaving work, pushing the clutch down and the car wouldnt go into gear for a good 20 seconds. after a little bit of driving it all went back to normal. Im thinking either air in the line...the clutch was changed by the previous owner, or a slave cylinder/master?
i was also reading that you can change the fluid as others have experienced the same problem. I think i may have to do that as the clutch becomes fine as soon as the car is driven for a little bit. it will be messed up one minute and fine the next. Is taking the fluid out with a syringe and pumping the pedal 25 times and repeat a few time sufficient to bleed the system, will this get all the air out or do i need to actually open the screw on the master?
Old Jul 17, 2008 | 08:57 AM
bump, cmon i know someone has done this, i just want to clarify what i have already read. thanks!
Old Jul 17, 2008 | 05:27 PM
cool....changed fluid things definetly "feel" different, fluid was a murky very dark tan/brown color
Old Jul 17, 2008 | 08:50 PM
mikeman2459's Avatar
i had the same problem the first week i got my 05 i had to bring it to the dealer and they said that because the pedal wouldnt always rebound all the way the clutch would slip so they replaced the clutch and fly wheel (i dont kow why the fly wheel but they did)
Old Jul 17, 2008 | 11:34 PM
it rebounds past the point of where it would be burning the clutch, it just seems a little sleepy. it still has like a 1/4 inch of play but i dont think thats really bad as there is like no resistance in this play. oh well, changing the fluid was a great idea, been better since
Old Jul 18, 2008 | 01:28 AM
Lip's Avatar
Lip
Just got my clutch master cylinder replaced, have the same exact issue.
Old Jul 21, 2008 | 11:19 AM
issue started acting up even more now. Im waiting for tony at riverside to get back to me so i can order up a new master and slave along with an SS line. any recommendations?
06g35
Feb 14, 2022 05:59 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
AL8782
Oct 3, 2015 10:26 AM
jbmw002
Sep 10, 2015 12:54 AM
