Drivetrain Loss
Old May 8, 2004 | 02:46 PM
Q45tech's Avatar
Re: Drivetrain Loss
Obviously the percentage varies with tires, tire temperatures, fluid temperatures, etc even hold down force on the straps.
It really only applies to peak rpms............what a group of testers found was necessary to convert some average RWHP to the published numbers given by manufacturers.
The power losses must be translated to heat rise - in automatics the greatest rise is in the ATF........in manuals the tires , then the diff fluid.
After all what counts is the RWHP not the flywheel power.
Old May 11, 2004 | 03:51 AM
n1cK's Avatar
G35 6MT
Re: Drivetrain Loss
well, i'm no engineer, so i don't even think i should attempt to, well........anywho, isn't friction just a function of force? this force acts against the force put on it, so if there is more force, there is more friction, yes? there is a point when the initial force overcomes friction, hence movement. i hope that kind of brings things on a new light, instead of either confusing the hell out of you or making me look like a, well, nevermind......
n1cK
jUs' bE [img]/w3timages/icons/cool.gif[/img]
Old May 11, 2004 | 05:01 PM
350gtboi's Avatar
Re: Drivetrain Loss
I agree with n1cK i think thats a good explanation..
Old May 11, 2004 | 06:29 PM
g35noob's Avatar
Re: Drivetrain Loss
haha yeah. frictional force is equal to the friction constant times the normal force. the greater the normal force ,the greater the friction. hence it is always expressed in a percentage for the reason nick said
04 5AT / TB / Willow / Premium / clear corners / Z-tube
Old May 11, 2004 | 07:47 PM
justICE's Avatar
Re: Drivetrain Loss
<hr></blockquote>
This is definitly in the right direction=). There are actually 2 types of friction forces (static and kinetic). To picture this think of looking through a microscope at 2 different surfaces pushed together (like a box on a table). Can you imagine how minature "valleys" of the table would be filled by little peaks of the box? To get the box sliding, a force would have to be applied so that those peaks would be pushed out of the valleys. This force is the static friction. The kinetic friction comes into play when the box is already moving. Those peaks would still try to come to rest within the valleys; however, because the box is moving it requires less force to overcome this tendancy. This is why if you have ever pushed a very heavy box across a table (or floor) it seems to take more force to get it started then to have it continuously sliding.
So back to the origional question. To really simplify just look at the most basic kinetic friction formula:
Fk (kinetic friction) = u (coefficient of friction) * Fn (normal force).
The coefficient of friction is a constant value (<1). So essentially it is a constant percentage just usually expressed in decimal form. =)
"I'm not saying you're full of BS, per se" - Zimbo
-JustICE
Old May 12, 2004 | 12:53 AM
n1cK's Avatar
G35 6MT
Re: Drivetrain Loss
well, i'm glad all are in agreement so far (i guess i'm not so dumb after-all, but i could be speaking too soon all in all, i agree with justICE in that his explanation is the reason why drivetrain loss is expressed as a percentage rather than a set value. the coefficient of friction would also tend to differ between different kinds of materials/metals, as well as lubricants used.
n1cK
Greenlawnracing
Engine - Intake/Fuel
Feb 21, 2016 10:39 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
zcherub
Aug 27, 2015 09:47 AM
