Problem: SLIP, Parking Brake & VDC Off Lights On
Old Jan 2, 2009 | 12:27 PM
-j.C-'s Avatar
Exclamation Problem: SLIP, Parking Brake & VDC Off Lights On
Hi
I'm having an issue with the VDC on my car. It's a 2004 G35 Coupe 5AT. Sometimes when it's cold outside (-5C or colder) while I'm driving at any speed three indicator lights come up on my dash.
I get the SLIP, Parking Brake & VDC Off lights on solid. When I try to restart the car it doesn't go away until I let it sit for about an hour.
While the three lights are on ABS works fine I just have no VDC.
(On a side note, I have been hearing the occasional squealing noise when starting my car in the cold as well I suspect power steering pump, fluid level is perfect) I'm not sure if it may be related...
Any thoughts?
Attached Thumbnails Problem: SLIP, Parking Brake & VDC Off Lights On-img_0174.jpg
Old Jan 2, 2009 | 02:13 PM
Canadian's Avatar
Canada, eh?
Its your brake fluid, it is low. Fill it to the max line and you'll be fine.
Old Jan 6, 2009 | 03:39 PM
-j.C-'s Avatar
Thanks a lot bro... Worked
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
