Transmission flush at 30k, need it again at 50k?
Old Jan 15, 2009 | 01:19 AM
kenempireex's Avatar
I had a transmission flush (automatic) at 30k mile 1 yr ago. right now the car hit 50k and the tran oil level almost hit the minimum line. Do I need to do another transmission oil change soon? Or do I need a power flush again???
Old Jan 15, 2009 | 01:23 AM
blown420's Avatar
i dont think autos need to be changed that much..
Old Jan 15, 2009 | 08:16 AM
uf20wop's Avatar
did you check when the car was idling?
i believe you're supposed to check ATF while the car is on
Old Jan 15, 2009 | 11:10 AM
mikeee2's Avatar
Where you guys purchase the A/T dipstick and how much does it cost?
Old Jan 15, 2009 | 11:18 AM
uf20wop's Avatar
lol?
Old Jan 15, 2009 | 11:20 AM
mikeee2's Avatar
Originally Posted by uf20wop
lol?
Isn't that cap bolted down? I have yet to check the fluid level on my car and I remembered reading on the forum that it doesn't come with the dipstick.
Ok, did a quick search. I guess the dipstick is there, just have to unscrew the bolt. 03 models are the ones that doesn't have dipstick.
Old Jan 15, 2009 | 12:24 PM
Yes, I did.
I drove 30 mile before I checked with the Hot indicator line. Oil level is at the minimum line. My question is...Do I need to add more?
Old Jan 15, 2009 | 12:47 PM
Q45tech's Avatar
Your warranty requires that you maintain all fluids at the correct FULL level for a reason.
Old Jan 15, 2009 | 01:00 PM
erklep's Avatar
nissan/infiniti reccommends you change every 30k miles. more than likely the last time you had it serviced, when they checked the fluid they checked it cold and it was showing full. as the vehicle warms up, the fluid will get pumped through and show lower on the dipstick. i say go add half a quart and drive it untill youre due for your next service at 60k
Old Jan 15, 2009 | 04:43 PM
uf20wop's Avatar
lol really? i have a 6MT so i wouldn't know... but that seems really weird they wouldn't provide a tranny dipstick
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
prinny
Nov 22, 2015 11:07 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
