My Clutch is going Dead!!!! WHHHYYYY
Old Jan 27, 2009 | 08:47 AM
Str8t G's Avatar
Hello My Fellow G’s
My car is a 2004 G35 Coupe, it’s a 6-speed manual transmission and I believe that my clutch is going dead!!!! I believe that because my clutch catches right before I take the foot of the clutch pedal , also sometimes it’s hard to shift into the next gear… actually it happens a lot where the shifting is hard… it also feels like my car is slaking at take of it used to be faster… And the clutch pedal is also hard when u press it down! I remember when I first got the car the shifting was really smooth u could do it with one finger now it shifts hard… Question for my G rider’s that had bad clutches do these symptoms sound familiar????
QUESTIONS???
1. What clutch do you guys suggest?
2. Should I change the Flywheel?
3. And what is the best clutch to put on a stock G35 and that wont mess up my gears or anything else!!!
P.S. JUST WANT TO SAY THANKS TO ALL THE GREAT PEOPLE ON THE WEBSITE AND A BIG THANKS TO G35DRIVER.COM!!!! THANK YOU FOR ALL YOUR HELP!!!
Old Jan 30, 2009 | 12:41 PM
JD_AND_DA_G_RIDE's Avatar
Originally Posted by Str8t G
Hello My Fellow G’s
QUESTIONS???
You may want to do a search on the forum but I've read that going with stock replacement is your best bet for reliability/durability. I may be wrong but I do believe that if possible you should change your flywheel as it may have be worn down especially if your clutch is going out. Sorry, wish I could give you better advice.
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Jpete
Sep 25, 2015 01:38 PM
eljefe7070g35
Sep 11, 2015 09:28 AM
