4.083 final drive question
Does anyone here know how to align the rear diff back up after you take it down? There is a sedan owner here who has a 4.083 final drive and I don't remember his user name.
I went by FP to ask but they were closed. And on my 350z there is a person who had a good write up on it but they said they didn't know how to align it. And they also said they had problems with the diff after the install.
what do you mean by align it?... You need to use a new crush spacer for the pinion gear to have enough pressure/pre-load... also proper shims are needed (and you wont know what size until install, so have many handy).
lol - yep, there's a bunch of stuff goin' on there... I've looked over the entire rear end in FSM a few times - its not a DIY for many ppl - certainly not me.
Been there, done that. Swapping gears is easy, but if you don't have the right tools to measure preload and shim size, there's no way the shadetree mechanic can do it. It's labor intensive, but really quite easy. Like others have said, leave it to the pro.
Don't feel bad. I've rebuilt engines and transmissions and yet still can't set up rings gears properly.
