trans and diff fluid...
Old Feb 19, 2009 | 03:30 PM
eagans2002's Avatar
i have an 03 coupe(6mt) and i need to know how much diff fluid and trans fluid i need and what type i need....i heard it was like a total of almost 4 qrts..?? GL-4?
Old Feb 19, 2009 | 03:51 PM
twin001's Avatar
Get four quarts for the transmission, you'll only use about 3.5 though. Two quarts will be enough for the differential (only need 1.5 qts). There's a few DIY's here (I did one for the transmission and submitted pics for the diff), give me a second and I'll post links.
Old Feb 19, 2009 | 03:53 PM
twin001's Avatar
Transmission Fluid:
https://g35driver.com/forums/engine-...ange-pics.html
Differential Fluid:
https://g35driver.com/forums/engine-...id-change.html
It's easy to do.
Old Feb 20, 2009 | 12:37 AM
eagans2002's Avatar
alright good stuff...thanks man
Old Feb 20, 2009 | 01:09 AM
G35-Jat's Avatar
Does anyone know if I can use the following oil in my diff:
Motel 300 Gear Oil 75w90 Synthetic
http://www.thenismoshop.com/ikorb.ph...roduct_id=1486
, Just been reading a lot about different api's want to make sure before i order this. Going to be using Nissan Tranny fluid for the Manual Tranny.
Thanks
Old Feb 20, 2009 | 01:17 AM
ttrank's Avatar
Grocery getter
No, it says for non LSD and yours will have a VLSD.
Old Feb 20, 2009 | 02:01 AM
G35-Jat's Avatar
Thanks!
Good thing I didnt order, will have to find some Amsoil...
Old Feb 20, 2009 | 12:43 PM
TheTick's Avatar
Just go to your local auto store and pick up some mobile1 gear oil. A lot of stores also carry Valvoline which is much less money and more than fine as long as you don't go more than 60k miles and don't track the car often.
Old Feb 20, 2009 | 01:57 PM
eagans2002's Avatar
ok so i went and bought the crush washers which wasnt more than 4 dollars total for both(nissan dealership)....but i went to pepboys after and they had some 75-90 fluids and one that stood out to me was royal purple(12.99 qt) and then there was i believe castrol and one other..they were both 9.99 a qt....but at nissan they recommended 80-90 which at nissan was 9.99 a qt also....should i got with the nissan fluid or go aftermarket???thanks guys for all the help much appreciated..
Old Feb 20, 2009 | 02:07 PM
twin001's Avatar
Make sure you use GL-4 for the transmission, not GL-5. The differential fluid should be GL-5, 80w-90 but 75w-90 will be fine. You aren't going to go wrong with the Nissan fluid, but you might save a little money by going aftermarket. I'm not even sure what Nissan charges for their fluid though, probably not much more.
Old Feb 20, 2009 | 02:18 PM
eagans2002's Avatar
lol ^^^^^^^^^ nissans was $9.99......so ill get 2 qrts of gl5 for the diff...and 4 qrts of gl4 for the tranny....if i read that right
alessandro
Oct 8, 2015 09:29 AM
Gwhut?
Sep 19, 2015 11:33 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
All G'd Up
Aug 29, 2015 12:40 AM
