Leaving car in gear??
Old Mar 21, 2009 | 05:32 PM
  #31
BrettFoxxG35's Avatar
Mainly --> neutral and ebrake
Both on the driveway.
Old Mar 22, 2009 | 06:20 PM
  #32
aannddyy's Avatar
The E-brake should be strong enough to hold the car in place.. unless you are living in areas such as San Fransisco where parking has to be done on slopes, then you would need to put your car in 1st gear w/ E brake. And no putting it in E brake does not damage the car in any way.
Old Mar 22, 2009 | 06:25 PM
  #33
teamspink20's Avatar
usually i leave it in neutral with the e-brake up
Old Mar 22, 2009 | 06:29 PM
  #34
BlackGGG1986's Avatar
Neutral + E-brake
Old Mar 22, 2009 | 07:36 PM
  #35
xXHotelCrazyXx's Avatar
Originally Posted by BlackGGG1986
Neutral + E-brake
Negative. 1st & ebrake. Just like you should have learned in school
Old Mar 22, 2009 | 09:36 PM
  #36
Still2Slow's Avatar
to op, It won't hurt your car, but I would still use the ebrake and turn your wheels on a hill. Luckily, there are no hills where I'm at so I just use the ebrake alone.
Old Mar 22, 2009 | 10:57 PM
  #37
Defs's Avatar
Originally Posted by baileyrx
put the car in reverse if pointing downhill, with the front tires turned towards the curb.
put the car in 1st gear if pointed uphill with the front tires pointing away from the curb.
of course using the e-brake...
Not a good idea unless you like spinning the engine backwards(bad things happen).
Put the car in 1st if pointed DOWN hill(if the car would roll forward), and reverse if you're pointed UP hill(car would roll backwards).
This will make the engine turn the correct way if the ebrake was to fail. The compression/friction force is the same either way.
Old Mar 22, 2009 | 11:59 PM
  #39
rob40wilson03's Avatar
i park it with it in the gear im gonna use when i move the car again (first or reverse, depending on the parking situation) and the e-brake
Old Mar 23, 2009 | 05:35 PM
  #40
Curt G's Avatar
Originally Posted by bomberman447
...not being used to leaving it in gear and having it jump forward everytime someone parks it in gear and I start it up.
Have you ever tried to start your car without pressing on the clutch?
Old Mar 23, 2009 | 06:05 PM
  #41
gr8huntr's Avatar
In my dodge i can't start my truck without the clutch being pushed down
Old Mar 23, 2009 | 06:07 PM
  #42
bomberman447's Avatar
No, I have always started with the clutch in.
Old Mar 23, 2009 | 07:25 PM
  #43
a_phamm's Avatar
when i park at a level ground or whatever i just throw it on first. i dont even use the ebrake. thats what carroll shelby does as well
Old Mar 24, 2009 | 06:50 PM
  #44
Curt G's Avatar
Exactly! Thanks gr8huntr. So leaving the car in gear when you park shouldn't involve worrying about the car lurching if you try to start it in gear, because it won't start that way.
Old Mar 24, 2009 | 08:20 PM
  #45
Xet's Avatar
Xet
i think they mean like starting up the car then releasing the clutch to do something else before you actually move (ie. like doing the bass fix on the bose systems fml). i have been surprised a few times when i forget i have left it in gear and i clutch in, turn on the car, and release the clutch and lurch forward and stall.
