Changing Manual Tranny Fluid
Old Jun 29, 2004 | 03:15 PM
soG35's Avatar
for those of you have done this, is it difficult? I'm planning on getting the service manual, but i'm not sure how much work this entails. Is checking the fluid level difficult also?
Old Jun 29, 2004 | 04:06 PM
THX723's Avatar
G Kreuzer
Re: Changing Manual Tranny Fluid
It's very simple. I'd say it's about on par with an oil change. You will need a fluid pump ($10-15) to transfer the fluid up stream into the fill hole and a good oil pan to catch the fluid.
Clint (THX723)
Old Jun 29, 2004 | 04:16 PM
AltaLad's Avatar
What I use for my manual trany/rear end diff oil changes are the small portable oil pumps available at your local marine shop for filling the lower gear case of a outboard motor. The pump screws on to the top of the oil bottle and the suction tube gets most of the oil out. It's quick, easy and no mess.
2003 G35 6MT DP Willow
Mods:
splash guards MING* Clear bra/corners
Aluminum pedals - Sirius radio
ZR3 & 8500 Escort
Rogue short shifter - Nismo parts
Duramax 6.6
Old Jun 29, 2004 | 04:25 PM
soG35's Avatar
thanks for the help!
Old Jun 29, 2004 | 04:26 PM
dklau33's Avatar
Agreed. Very easy. These are the basic steps.
1. Get the car up on jackstands on all 4 corners to give yourself ample room.
2. Locate the filler plug on the side of the tranny case and open with 3/8" Hex Drive Bit.
3. Locate the drain plug on the end of the tranny case with a 3/8" Hex Drive Bit to undo the drain plug.
4. Drain oil into pan.
5. Replace drain plug.
6. Replace tranny fluid with 3.25 qts of fluid. The service manual recommends using the following viscocity. You will need a gear oil pump to send the new fluid up stream into the tranny case.
Genuine NISSAN Manual Transmission Fluid
(MTF) HQ Multi 75W-85 or API GL-4, Viscosity
SAE 75W-85 or 75W-90
7. Replace filler plug.
Since this is such an easy procedure I will change my tranny fluid every 15K instead of the recommended 30K on the manual. Doesn't hurt.
04' G35S 6MT Ivory Pearl, Willow, Premium
Z-Tube / NFC Y-Pipe / Coupe Mid-Pipe / 350 EVO Rear Sway
Old Jul 2, 2004 | 02:41 AM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
hey darren...
let me know when you change your tranny fluid.
i might join you to learn and possibly change mines out as well.
vinh
Golden Gate G35 Club
Old Jul 2, 2004 | 02:47 AM
richie's Avatar
I changed my manual tranny fluid on my old car and I don't think its worth it.....I mean all the work (4 jack stands)
I think I would take it to a dealer...or somewhere with a lift...they could do it quick..its not even that costly.....
Getting the car on all 4 jack stands is kinda scary to me......
Old Jul 2, 2004 | 01:04 PM
SagiSRP's Avatar
I'll probably do a tranny fluid change after my break-in.. which is in like a couple hundred miles.. gonna use royal purple.. anyone in the bay up for a tranny fluid change weekend? hehe
Blakearold
Aug 19, 2015 10:20 AM
linedr89
Aug 17, 2015 05:11 PM
bdnbfrank
Aug 17, 2015 02:09 PM
NemesisGee
Aug 11, 2015 07:10 PM
Cskeet
Jul 21, 2015 05:48 PM
