Difference between 3.3 and 3.5 gears when installed
Old Apr 4, 2009 | 11:31 PM
OCG35's Avatar
Originally Posted by 4drmadness
The pumpkin has vlsd, both wheels turn in the same direction. Its a 3.3. I will contact the seller and let him know asap.
how does 3.3 fit with vlsd?... the 3.3 ring gear is thicker than 3.5 (which is the MT FD and typically only MT has vlsd)... I think there was an option for vlsd for AT at one point(but I'm not positive) - I dont know if it was a different size differential or if those gears were 3.5?... but 3.3 FD will not fit with an MT differential.
What made you determine you have 3.3?
Old Apr 4, 2009 | 11:32 PM
OCG35's Avatar
Originally Posted by ttrank
I went from a 3.5 to a 3.3 on my 6MT to help with traction issues. It helps quite a bit . My 6th gear rpm at 70mph on the freeway is 700rpm lower.
Tim, what LSD are you using with the 3.3?
Old Apr 5, 2009 | 12:33 AM
infinus's Avatar
my 05 AT has the 3.3 with VLSD.
Old Apr 5, 2009 | 08:47 PM
RADIOGUY21's Avatar
yeah if you got the sport package with the 5AT, you have a VLSD. So yes they offered a VLSD with the 3.3 FD.
Old Apr 5, 2009 | 10:34 PM
OCG35's Avatar
I believe that didn’t happen till late 03-04 though (mid mid 04?)... I know someone with an early 03 sport package and I dont think vlsd wasn’t an option... I could be wrong, but I'm pretty sure it wasnt offered initially.
Old Apr 5, 2009 | 10:39 PM
OCG35's Avatar
I just looked up the original sales brochures... it was not offered until 05. Standard with the MT sports package and available with the AT sport package... it wasn’t an option prior to 05.
Old Apr 5, 2009 | 11:03 PM
RADIOGUY21's Avatar
yes you are correct. Only the 03-04 6MTs had a VLSD, ATs were an open diff. 05+ sport package 5AT and 6MT had a VLSD. So 05+ 5AT had a 3.3 FD with the VLSD.
chinee
Jun 10, 2024 07:48 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
bjo16
Aug 4, 2015 09:52 AM
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
Aug 1, 2015 12:00 PM
ANMVQ
Drivetrain
Jul 20, 2015 04:10 PM
