10mm hex key for differential / transfer bolt...
Old Apr 4, 2009 | 09:54 AM
mikeee2's Avatar
Originally Posted by jimNC
Get a 10mm hex 3/8 socket. If you use an L-wrench you might be able to get it off (by sliding something over the handle for more leverage) but if you use a socket you can actually torque it back on there at the correct setting (25 ft-lb).
I've got a pretty large socket set but no hex sockets so I just bought this one singly. Just hope I don't lose it since I don't use it for anything else
If you are gonna use an L-wrench then make sure you break the fill plug first, in case you can't break the drain plug. Probably should do it in that order regardless.
Edit: if you have a torque wrench it is probably 1/2" drive so either get a 1/2" socket or make sure you have a 1/2" to 3/8" adapter.
I have a torque wrench and 1/2 to 3/8 so all I would need is the 3/8 10mm hex. Thanks...
Old Apr 4, 2009 | 08:32 PM
ttrank's Avatar
Grocery getter
I have a Matco set that has a 3/8 socket to metric hex. Not 100% sure what size but it fits perfect.
Old Apr 4, 2009 | 08:49 PM
willthethrill's Avatar
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
f22raptor
Mar 18, 2016 08:50 AM
G35xdriver04
Nov 7, 2015 08:31 PM
