Clutch Pedal Problem
Old Jul 25, 2009 | 07:45 PM
  #31
pczavala's Avatar
Originally Posted by oyoquem
Your clutch pedal finally stuck Daniel. I got a steel line recently, I'll probably install it this week and bleed the fluid when I get a chance.
give me a call when you do it ill go help you out and then you can bleed my line too
Old Jul 25, 2009 | 08:15 PM
  #32
mconklin's Avatar
Mine did that to..when I tried to engage it at high rpms, this seems to be a pretty common problem..the dealer warrantied the flywheel, so I just bought aftermarket parts had them put them in and it hasn't done it since. I can dump the clutch all day long.
Old Jul 31, 2009 | 12:45 AM
  #33
MaeLaMer's Avatar
Awesome! My clutch got stuck today too. It was about 94 degrees outside and I was in city traffic. I had to constantly lift the clutch all the way up with my foot after every shift. I went to test the car again at night, 79 degrees outside this time, and the clutch was working like normal. It sounds very likely that a new stainless steel braded clutch line and DOT 4 fluid should do the trick. Thank you everybody's contribution to this thread and I will update on the situation.
Old Jul 31, 2009 | 01:13 AM
  #34
pczavala's Avatar
mine was also around the same temp maybe 96 and it was city driving also, I changed my fluid and test drove it a few minutes after it was sticking and hasnt happened anymore since. back to normal =)
Old Jul 31, 2009 | 03:12 AM
  #35
oyoquem's Avatar
Did you do the suck out the fluid and put fresh fluid then pump pump? Or did you bleed them.
Old Aug 1, 2009 | 02:01 PM
  #36
pczavala's Avatar
sucked it out, pumped the pedal, drove it around the block, then repeat about 4 times lol
Old Aug 4, 2009 | 03:49 PM
  #37
SPEC-01's Avatar
I have actually started to see this happen with my car too. I have bled the system and the issue has returned. I have a master on the way as we speak and a stainless clutch line in route too. The funny thing is that I am already RBF-600 fluid, which I have used for years in my track cars without issue. In fact after changing to the RBF the fluid has been clean and clear which means that it isn't boiling. That being said I will be changeing out parts soon and will let you know what I find. Thanks,
Old Aug 7, 2009 | 11:39 PM
  #38
OBsessed's Avatar
Really really glad I found this thread. I've been noticing the same issue (inconsistently of course) for about a month and was worried that I'd have to replace the clutch. Will be ordering up a the better clutch line and give this a shot first. Thanks for all the info you've all put into this
Old Aug 14, 2009 | 08:01 PM
  #39
KhanArt's Avatar
Noticed this happening to me recently, its off and on. Annoying but I guess if it continues I will have to do something
Old Aug 14, 2009 | 08:32 PM
  #40
CltCoupe07's Avatar
What stainless steel line does everyone recommend? I see the NISMO one on g35parts for like a hundred bucks, any other options out there?
Old Aug 17, 2009 | 02:00 PM
  #41
SPEC-01's Avatar
I ordered my line from Agency Power. I also got brake lines from them too. I will post up some pics and reviews as soon as I have some time to take my car down.
Old Aug 21, 2009 | 10:21 PM
  #42
Gd35up's Avatar
I just started experiencing this problem today as well. I searched up a video on youtube and this is exactly whats going on.
Is this the same problem that you guys are having as well?
Old Aug 21, 2009 | 10:45 PM
  #43
KhanArt's Avatar
http://www.youtube.com/watch?v=KDILpFOdJD8
Yup, thats the same problem im having. Its off and on on my car. I dont know if the temp or hard driving has something to do with it but it could be. It happens when I shift to 1rst and 2nd, the other gears it comes back up. When this happens I just pop it back up with my foot.
Whats the fix for this? Whats the cause?
Old Aug 22, 2009 | 03:34 AM
  #44
Skaterbasist's Avatar
Retired SuperMod
I have the same issues.
It's not something that happens on a consistent basis, but I notice it usually occurs during hot days on stop-&-go traffic.
When releasing the clutch pedal, it would come up to about 80% (above the engagement point), then get stuck. It usually releases about a second or so after, but it's not a pleasant feeling.
Old Aug 22, 2009 | 03:36 AM
  #45
Retired SuperMod
This is exactly it, but it only happens to me during specific events (as explained in my previous post).
