Automatic Transmission: Drain & Refill vs Flush
Old Sep 14, 2011 | 03:02 AM
  #61
geegeegee's Avatar
Sorry to bring this thread back.
Anyways, I've read through all the posts, and considered taking jibberjabber's advice, but am still unsure whether I should flush or just drain and fill my ATF. Well, my car is at 90k (yes, I know I've waited too long) and the previous owner has never changed or flushed the ATF. My question is, since I've gone so long without a ATF change, should I still just do a drain and fill, or just take it in to the dealer and flush it?
I'm only asking this question because I seem to be the only one who hasn't changed the fluid in such a long time. What do you guys think?
Old Sep 14, 2011 | 08:32 AM
  #62
Mustang5L5's Avatar
I think a drain/fill is less invasive.
My experience with old crappy cars is once you get over 100K miles, don't flush the trans. I've had cars start slipping at that point.
Old Sep 23, 2011 | 03:51 AM
  #63
Trickstyle's Avatar
ima do a full drain via MardiGrasMax's advice...
Originally Posted by MardiGrasMax
you can do the flush yourself, drain the trans, its about 4qts, fill it ip with 4 qts, take the trans cooler line off the cooler and put it in a 4 qt empty oil jug, have some one run the motor, 2 qts of the old fluid will pump out in 10 seconds or so, add 2 qts, repeat this step a few time and the fluid color will change when the new fluid comes out. check the level and top it off if neede, good to go, thats how its done in the FSM too,
Old Feb 25, 2016 | 01:07 PM
  #64
abrecos's Avatar
Just wondering where is that transmission cooler return line is located.I want to do flush myself but have no idea where is cooler return line.
Old Feb 25, 2016 | 06:38 PM
  #65
coffeysm's Avatar
The radiator cools the ATF fluid. It's the two smaller hoses on the bottom of it, but I don't remember which one is the return.
Old Jun 9, 2016 | 06:25 PM
  #66
Ferinthul's Avatar
Anyone have pics of these steps?
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
Chauzilla
Sep 27, 2015 04:34 PM
blnewt
Sep 25, 2015 01:48 PM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
