Rear final drive
Old Sep 9, 2009 | 07:40 PM
XDR-V35's Avatar
Rear final drive
ok i have a couple questions on this.. i assume my 03 5at sedan has 3.3 no vlsd. what vehicles came with 3.5 or 3.7 vlsd that would be a direct bolt in replacement? i found this chart below but dont know how accurate it is, anyone have anymore info on what ones have what gears for what years, for both g35 and 350z, and what will bolt into what.
rear, AWD (3.692 ratio)
rear, RWD, 4 Dr (Sdn, 3.692 ratio), locking, MT
rear, RWD, 4 Dr (Sdn, 3.692 ratio), locking, AT
rear, RWD, 4 Dr (Sdn, 3.692 ratio), non-locking
rear, RWD, 2 Dr (Cpe, 3.538 ratio), locking
rear, RWD, 2 Dr (Cpe, 3.538 ratio), non-locking
Old Sep 17, 2009 | 11:13 PM
Tollboothwilley's Avatar
dunno where you got that list, but thats not right
03-04 5AT = 3.3 gears
03-06 AWD = 3.5
03-04 MT with sport = 3.5 with VLSD
05-06 MT = 3.5 with VLSD
05-06 5AT with sport = Not sure...some say it has VLSD and could have 3.5 gears as well.
Old Sep 17, 2009 | 11:15 PM
Also 04+ 350Z's that are not BASE model will have a VLSD...manual is 3.5 gears.
Old Sep 18, 2009 | 01:56 AM
officerdbag's Avatar
Every AUTO 1st gen G sedan or coupe in RWD comes with 3.3 gears
Every MANUAL 1st gen G sedan or coupe comes with 3.5
2nd Gen G35 sedans all come with 3.7 gears.
All diffs from G35's and 350z's are compatible/swappable.. Not sure about AWD though. I think they come with 3.7
Old Sep 20, 2009 | 10:37 PM
sliderg35's Avatar
You are perfectly set to drop in a MT Quaife with MT 3.5 gears - I did. The Quaife requires open diff - which you have. The difference in unbelievable. I live in Canada so I have to deal with snow also. Until the switch the car was not really drivable in snow because the VDC would cut in and stop the spinning wheel - then the other wheel would spin... and the VDC would stop that wheel... You get the picture. With the Quaife, even in snow the car moves when you hit the gas. The only way to spin a wheel is to have them both spin. So, lets talk about what happens with FI on dry pavement - WOW! Enough said. I can still cut loose in 3rd if I floor it, but both wheels spin (I do need VDC off for that).
Old Sep 22, 2009 | 01:01 PM
Quaife uses the open diff huh? I didnt know that. good to know. Expensive swap out though, right?
Old Oct 20, 2009 | 10:05 PM
ttrank's Avatar
Grocery getter
Quaife does not require the open dif. They make ones for all three, auto vlsd, manual vlsd and open diff.
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
Ninjay16
Jul 20, 2015 01:21 AM
