Manual mode and D mode differences?
Old Aug 13, 2004 | 08:35 AM
Catatafish's Avatar
Re: Manual mode and D mode differences?
ChicagoX makes some very good points.
I'd just add that I believe my slower times in MM are a result of my reflexes, my inability to shift at the exact proper time, and the fact that the tach is unreliable approaching redline due to "velocity blah blah" (a term I remember Q45Tech using in another post).
At stock, the auto shifts, I believe, at the optimal time by itself. When modifications are made, the HP/TQ curves have changed and by having more power here or there, the optimal shift points have changed, thus the TS reflash may be beneficial by allowing the driver to shift at the optimal time, whereas before the mods I'm not so sure increasing the shift point to a higher RPM is beneficial at all.
This can easily be calculated using the following, if the data required to calculate is known, and it can be after the mods if the new peaks are known....which if properly dynoed can be known.
http://home.neo.rr.com/chambersracing/shift_points.htm
http://www.bgsoflex.com/shifter.html
2004.5 Coupe/5AT/Ivory/Everything but front spoiler/Nismo CAI/Crawford V5/Crawford Cats
Old Aug 13, 2004 | 10:27 AM
cato's Avatar
SouthernComfort Moderator
PM gord (Gordon Gee) gordgee for a set of hypergrounding
wires. You will want all 10 of them. Wire #7 is a bit&h to
install, the rest are fairly easy.
03 5AT Sedan, sunroof, splashguards, HKS muffler,
14 wire Grounding kit, Z Duct, Stillen HF/AB
Underbody rear diffusers, Drilled alum pedals,
Stillen sway bars H/H
Old Aug 16, 2004 | 01:37 PM
SixFive's Avatar
While some responses speak to you needing to reset the ecu every hour...just try it once and it will last about 2 weeks or possibly much more depending on how you drive. The TCU is not reacting as quickly as some would suggest the UCU adapts. The ECU adaptability has not yet been argues convincingly either way so we dont really know what's up there with all the opposing facts. The TCU does take weeks to adapt to slower driving habits and it takes much much more than an hour to go from fast shifts to slow ones. I reset every 45 days or so...I think people are confusing the reset of the ecu with the resetting of the TCU when referring to transmission issues...
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Aug 16, 2004 | 01:46 PM
SixFive's Avatar
PS cant edit "UCU" above to be "ECU"
Also , while the TCU is adaptive, the algorythm supposedly is for long term adaptablity meaning that an hour makes a difference perhaps, but really not much worth mentioning from my experience. I dont notice any changes until at least 2 weeks after resetting.
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Aug 16, 2004 | 03:23 PM
EZZ's Avatar
EZZ
SixFive,
How do you reset the TCU? Do you touch the +/- terminals for several seconds or just leave the car unplugged.
04 Coupe Auto/DG/Prem/Nav/Perf
Old Aug 16, 2004 | 03:36 PM
SixFive's Avatar
You are, by default, resetting the TCU when you reset the ECU. It can all be reset using the pedal method or the 12 hour method.
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
magnetism80
Feb 1, 2019 10:00 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
n2fooz
Sep 4, 2015 07:46 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
