Need New CLutch Advice
Old Nov 29, 2009 | 11:38 PM
jigied4lif's Avatar
wasup people's, I have a 05 6mt g35, i think My g is getting to the stage where a new clutch is needed. This is my first clutch change so i am a novice at this. I would really appreaciate any advise or any suggestions on good clutches, what stage clutch , what flywheels, "COSTS" etc so i can make the best choice... thank you
Old Nov 30, 2009 | 12:52 AM
SILVERSURFERG35's Avatar
Get the ACT heavy duty pressure plate with the street disc . Get the lighter flywheel to . Best combo from all the people that I know have gotten new clutch . Trust me .
Old Nov 30, 2009 | 01:34 AM
HenryLee's Avatar
Make sure your ready for clutch noise. Most aftermarket clutches make the "chatter" noise. But I've heard good stuff about JWT clutch and flywheel combo. But how many miles do you have on your car?
Old Nov 30, 2009 | 02:58 PM
jigied4lif's Avatar
my car has 57000 miles this is going to be the first of many to be fixed i guess lol
Old Dec 2, 2009 | 04:17 PM
SPEC-01's Avatar
Henry, the clutch actually doesn't make any noise and neither does the flywheel itself. The sound that you hear when moving to a single-mass flywheel actually originates in the transmission and it occurs as a result of the elimination of the dampened stock dual-mass flywheel. The sound is called clatter (a.k.a. gear noise or gear rattle) and this doesn't evidence any issue.
If you want to keep this clatter to a minimum then I suggest that you opt for a steel flywheel (like the SN35S offered by SPEC) which has greater mass and thus more dampening than a lighter aluminum flywheel. As a side note, gear noise is most audible at idle with the pedal released and during deceleration and high load (read low RPM/high-gear) acceleration. It really isn't that bad at all. I have an SN35S steel flywheel and a SN353H Stage 2+ clutch in my 2005 G35 Sedan. Let me know if you have any further questions. Thanks!
Old Dec 9, 2009 | 10:39 PM
Tollboothwilley's Avatar
what are the differences in weight for the SPEC clutches/flywheels?
Old Dec 9, 2009 | 10:47 PM
Gargan's Avatar
Mine started slipping around 54k miles and I had it replaced with a JWT clutch/flywheel combo. $1300 all said and done, but I'm much happier with the overall feel compared to stock. Although it doesn't bother me at all, there is a noticeable increase in noise from the lighter flywheel.
Old Dec 10, 2009 | 02:42 PM
kenasaki's Avatar
yeah, im in need of a new clutch, flywheel, or whatever the issue may be as well. mine when at 33k and now its at 43k. It slips, ALOT when i try to smash from 2nd gear onwards. Such an annoying feeling. I was thinking of just getting an oem replacement, bc i get annoyed of chatter, but I do bump my music loud so maybe it'll cancel the chatter out? haha
Old Dec 14, 2009 | 09:54 AM
SPEC-01's Avatar
I apologize for the delayed response. I was out of the office last week at PRI. Are you asking about the difference in weight for the Steel and Aluminum flywheels?
If so, the Steel flywheel weighs 27.6-lbs and the Aluminum flywheel weighs 14.2-lbs. Let me know if you have any further questions. Thanks!
Old Jan 8, 2010 | 03:23 AM
jigied4lif's Avatar
i am also having trouble deciding a good place to get them done, should go with the dealer, or go to a local transmission shop or a regular mechanic?
Old Jan 9, 2010 | 10:36 AM
InShAllAh's Avatar
SEARCH....
Sorry I'll be that guy, but there's three dam& threads just like this one on the first page alone.
I only say this because for us people who actually do search, repeat threads like this make it a PITA to find good threads to read when lookin for information.
SORRY BRO, don't take it personal!
Rose M
Oct 12, 2015 10:00 AM
6spdGspot
Oct 5, 2015 01:55 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
