OEM Pivot bearing w/ performance clutch replacement?
Old Mar 30, 2010 | 07:59 AM
draco1020x's Avatar
I'm gettin new JWT HD clutch installed tomorow and I'm wondering if anyone has any input on the pivot bearing. Should I be alright reusing the old one or should I have it replaced? Are the oem ones really as bad as vendors say, or r they jus trying to sell u one of those heavy duty ones? Becuz if need be I'll replace it with an oem one but if it's not really needed I'll hold off. I also don't wanna replace it with an oem one if it's goin to break using the JWT. I'm only running basic bolt ons so it not a crazy amount of torque added. Has anyone had a problem with oem pivot bearing and aftermarket performance clutch?
Old Mar 30, 2010 | 08:21 AM
GreenGoblin's Avatar
The goblin resurrection
Should not even be a question... A few bucks vs lots more in labor if you even need to change it.
Old Mar 30, 2010 | 12:07 PM
draco1020x's Avatar
Is the Oem one fine?
Old Mar 30, 2010 | 11:50 PM
Tollboothwilley's Avatar
OEM is fine. some aftermarket kits come with it...like the JWT clutch/flywheel combo from CZP
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dseet
Oct 11, 2015 12:40 AM
AL8782
Oct 3, 2015 10:26 AM
Learned Hand
Oct 1, 2015 09:02 AM
