2004 G35 Stuck in Manual Mode/Neutral
Old Jun 27, 2010 | 12:13 PM
sshuttlesworth's Avatar
On Friday night when i went to park my car the shifter accidently shifted over into the manual mode. I tried to put it back into drive but the shifter was stuck. I cant take my keys out or put the car into park. I have 74k on the odometer and im not trying to see the dealer. I noticed it happened to quite a few ppl with these cars and it didnt take long for the car to be fixed. I was wondering does anyone know what the problem is.
Old Jun 28, 2010 | 10:31 AM
Tollboothwilley's Avatar
Remove the Shifter (platic cover slides down, remove metal clip, pull assembly up)
Lift center console up - disconnect wiring clips
You should be able to move it around now - enough to free it up and put it back where it should go
Old Jun 28, 2010 | 10:36 AM
herrschaft's Avatar
Damn, three separate threads
Hope you find out whats wrong with it.
Old Jun 28, 2010 | 10:55 AM
im about to go try this right now!!!! hopefully it'll work
and i gotta find something out lol
Old Aug 17, 2010 | 12:19 AM
morvegil's Avatar
help
Same issue here! Cant shift. Took apart the center console. It seems the shift is "LOCKED" into manual mode. I cant get it to MOVE over to the AUTO modes. Is there a LOCK somewhere?
Old Oct 10, 2011 | 12:19 AM
hi-tek22's Avatar
Same here. Bump for a fix....I even have pics with the center console taken apart. My digital shifter shows blank....but when I force my Shifter over half an inch it goes from blank to "N" which is still incorrect because the far left should be "D"
Old Dec 6, 2011 | 03:34 PM
RADRaze2KX's Avatar
gonna try this at lunch, i was almost sideswiped this morning when my car decided to do this during a turn from a small street onto a busy freeway. Which wiring clips are supposed to be disconnected, and what caused this issue?
vmcarbuyer
Oct 12, 2019 12:42 PM
brycealbr
Aug 11, 2015 11:47 AM
igking
Jul 19, 2015 01:12 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
