performance clutches
Old Jul 29, 2010 | 12:51 PM
Beebo's Avatar
how long do performance aftermarket clutches last on a pretty much stock G?
i have the JWT clutch and it burned out in a year and 3 months
Old Jul 29, 2010 | 12:56 PM
alfhasg35's Avatar
r u burning it ?..or maybe it is a defective clutch.. i had a stock clutch last 70k miles and would have lasted longer but i got a new motor and opted to put in a JWT clutch as when they did the motor swap... 15mos is crazy mang..~!
Old Jul 29, 2010 | 01:38 PM
Beebo's Avatar
it may be defective, im going to take pictures and send them to JWT today. my transmission shop did say its burned its done but he said it may be defective. ill see what he says when i go by today
Old Jul 29, 2010 | 02:33 PM
sakataj's Avatar
if its burned, i doubt they will warranty it..... GL
Old Jul 29, 2010 | 06:52 PM
Beebo's Avatar
here is what it looks like
is there any clutch and flywheel combo that cost about the same as the JWT but better. im iffy buying another JWT clutch flywheel combo
Old Jul 30, 2010 | 02:29 AM
Beebo's Avatar
Bump
Old Jul 30, 2010 | 01:57 PM
Beebo's Avatar
guys what brand should i get?
ACT, SPEC, EXEDY?
I need a clutch and flywheel
Old Jul 30, 2010 | 02:16 PM
soifigured's Avatar
Looks like you got some hot spots on your flywheel. How did you drive your car? From what I see it looks like the clutch was used with enthusiasm.
On second glace it could also just be the nature of the replaceable surface that JWT uses.
Personally I would just grab an exedy stage I, if you're NA. 1000KG clamping force vs 1200 makes for easier driving if it's your daily driver!
Old Jul 30, 2010 | 02:28 PM
Beebo's Avatar
honestly i drive normal most of the time, no hard or power shifts. i am random with my spirited driving and do the occasional launches and a few donuts in 2nd gear. noting that would burn out a clutch though. there are two people that drive the car though
my mom and i so that may have helped it go out faster with the different driving styles
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Video Share
Jan 31, 2017 04:00 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
