wheel bearing issue?
Old Sep 11, 2010 | 09:56 PM
whoisthis's Avatar
Originally Posted by dukehotty
You should make sure you take the car in before your drivetrain warranty expires. I just had my front hub bearings changed for free.. it did not solve the problem.. but I am sure the sound I hear and feel is due to my front tires being feathered..
My car is 05 lol..no more warranty.
How does drive train warranty cover wheel bearings? Aren't they wear and tear items?
Old Sep 13, 2010 | 04:44 PM
culi's Avatar
The DIY out there is pretty detailed. I just changed both bearing and hub. While you're at it, go ahead and re-grease your axle. Don't forget to release your hand break to take the rotor out. I would suggest lowering your spring housing so you can get the axle out easily. Jack up the spring housing about 1/8" to 1/4" and remove the nut/bolt. Then lower the jack slowly.
Old Sep 13, 2010 | 09:51 PM
whoisthis's Avatar
I have a 350z. I've taken out the axles to grease them few months back. it was major pain in the **** to remove the axles. to make it easier, I can use a pulley to separate the hub from the bearings, right?
Old Sep 14, 2010 | 12:47 AM
culi's Avatar
I think it would be easier to get the whole hub/bearing assembly from the car and take it to a shop to have the old bearing press out, and then press the new bearing in. It shouldn't be that much to press out/in a bearing. Takes about a minute.
Old Sep 14, 2010 | 02:09 AM
whoisthis's Avatar
I think i'm just gonna go with the bearings. I'm going to attend Riverside car show and buy the bearings over there lol good timing.
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
rping
Jul 26, 2015 09:53 PM
itschuckster
Jul 25, 2015 08:07 AM
