Not Shifting!!!
Old Sep 7, 2010 | 09:38 AM
geis's Avatar
Exclamation Not Shifting!!!
I really hope my tranny didn't take a crap but I'm thinking it's what it is.
2005 G35 Sedan, 90k miles, Automatic. Been running just fine. Not troubles with engine nor tranny. Had it sitting in the garage all weekend and when I get it out this morning to go to work, it will not shift and I notice the Check engine light is on. Even when I go over to manual shift the gears on the dash says I'm going up and down but I can feel and see the Rpms getting higher and no shifting. Haven't got it in the shop yet to check the code. Just wondering if anyone has seen or heard of this before.
Horrible tuesday morning.....
Old Sep 9, 2010 | 10:43 AM
geis's Avatar
Two errors codes came up:
P1774 - Low Coast Brake Solenoid
P1731 - 1st Engine Brakeing
Anyone have any experience on these? Going be a sensor/solenoid replacement but not sure where yet.
Old Sep 9, 2010 | 11:24 AM
Tollboothwilley's Avatar
Either your tranny is shot (if you haven't had issues with shifting before this point I woulnd't guess this) or you are losing a solenoid or 2 in the valve body.
I bet its the solenoid gone out in the valve body.
I dont think you can purchase just 1 solenoid for the valve body - i think the whole assembly has to be replaced. Hopefully you can find a place that will sell just one so you can check.
Its not that difficult of a replacement, but it will definetly be messy
Old Sep 9, 2010 | 12:57 PM
geis's Avatar
Has anyone every replaced speed sensor/ solenoid or the whole control value assembly on their transmission before that could give me some insights?
Old Sep 21, 2010 | 11:34 PM
iPim's Avatar
anyone ?
Old Sep 22, 2010 | 02:13 PM
i've removed and replaced the VB and all the solenoids. What insights are you looking for?
Its a messy job, you have to use a diagram to make sure you get the bolts back in the right locations for the right size bolt.
Old Sep 22, 2010 | 04:46 PM
CBRworm's Avatar
20 Year Member
It's not low on ATF is it?
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
