Clutch fix spring removal mod diy complete!
Old Oct 26, 2010 | 05:06 PM
  #46
DT35G's Avatar
Originally Posted by ThickG
Played hookie and completed this today. Took me about 2 hours with taking my time and having some trouble getting the assembly back in. Went out for a ride and it feels great! This combined with the other pedal spacer mod has given a much improved feel when shifting.
Thanks for the DIY!
Whats the pedal spacer mod? Is there a DIY on here and an explanation of what it does? Thanks
Old Oct 26, 2010 | 07:31 PM
  #47
gphoenix's Avatar
Hey Guys it works!!!!!
the clucth pedals feels better then Ever, i did it on my 06 coupe
Old Oct 27, 2010 | 12:47 AM
  #48
ThickG's Avatar
Originally Posted by saywat?
^idk man i kind of like the push back feeling the clutch has. im assuming the spring is what pusshes the clutch back up. does that pressure get totally removed?
As DT35g alluded to, if anything, this mod increases the push back from the clutch. The spring seems to work both ways, in that, it helps disengage the flywheel as well as push the clutch back, which in turn makes the clutch action very...uniform. With this mod, you can feel the engagement point of the clutch which provides better feedback and helps improve shifting.
Here is the mod for the 1st gen: https://g35driver.com/forums/engine-...al-remedy.html
...and here it is for the 2nd gen: https://g35driver.com/forums/v36-diy...al-travel.html
The second DIY has a bit more of a permanent method, but the idea is the same. Essentially, you're adding a spacer to the activation points in the clutch assembly which decreases the pedal travel. I have it and like it, but I suggest following the less permanent solution first to see if it's something you like before going the permanent route.
Old Oct 27, 2010 | 08:42 PM
  #49
DT35G's Avatar
^^ Thanks, im gonna give this a try to. Dont think ive ever really noticed the extra travel until i read this thread. lol, now im excited about going for it. Its these little mods that make the love for driving my G stronger every day! Hahaha.
Old Oct 28, 2010 | 01:52 AM
  #50
ThickG's Avatar
I hear ya man! That's why I love this forum as well as the car. I never would have thought to take out that spring if it hadn't been for G35driver. Plus, the best mods are the ones that only take a little bit of elbow grease and know-how.
Old Dec 7, 2010 | 10:32 AM
  #51
DT35G's Avatar
Just an update, its been a couple months now and my clutch still feels great. No issues what so ever and ive transitioned from the warm weather to the cold since doing it. Hope people are still benefiting from this!
Old Dec 18, 2010 | 01:43 AM
  #52
WACK BEATS's Avatar
Anyone have a write up or video on how to do this? the original video is not working. Thanks!!
Old Dec 18, 2010 | 09:00 AM
  #53
SilverMamba's Avatar
does this help with the high engagement?
Old Dec 18, 2010 | 10:17 AM
  #54
DT35G's Avatar
ill repost it for you or send it to you directly. sorry about that. give me a little bit
Old Dec 18, 2010 | 03:41 PM
  #55
WACK BEATS's Avatar
No problem. Thanks !
Old Dec 19, 2010 | 02:21 AM
  #56
xeroglock's Avatar
^ me too please..
Old Jan 3, 2012 | 06:03 PM
  #57
P.F.'s Avatar
Can someone please repost the video?
Old May 29, 2012 | 12:54 PM
  #58
westbank23's Avatar
Bump video not working
Old Jun 16, 2012 | 12:50 AM
  #59
Plam's Avatar
I really want this video ]: can someone repost it or make a new DIY
Old Feb 16, 2013 | 12:42 PM
  #60
Metaxa07's Avatar
Bump /\
